Jason27
I'm adding a bathroom to the basement and dug a trench in the concrete. Laying the PVC and determining what to do with the 4 3 Closet Bend prior to redoing the concrete. I will be tiling the floor and assume a 1/4" to 3/8" or so height for tile and thinset. I can do one of the following:
1) Secure the 4 3 closet bend flush or perhaps a 1/4" above the level of the concrete. I'd then use a spigot 4" toilet flange once the tile is finished.
2) Put a 4" pipe in the 4 3 Closet Bend stubbed above the concrete. The closet bend would be then completely submerged below the concrete. I'd then cut the 4" pipe after laying tile flush withe the tile and use a 4" Hub toilet flange.
Thoughts on the preferred approach? Or does it not really matter? I think the 1st method will give me more pitch however I have 7" from the bottom of the slab to the top of the inlet pipe to the ejector pit with a 16'- 3" pipe run so that gives me plenty to fit within the 1/8" per foot minimum either way.
