Yet another 10" TOTO toilet recommendation request
Strong son
Virginia
Hi,
I have a small bathroom in Virginia. We have a Kohler Cimarron about 5 years old. We replaced because the previous toilet kept plugging. The Kohler Cimarron has been relatively good except for the last year or so when it is starting to block up more often even with minimal waste.
I am doing a bathroom remodel and decided to add in a new toilet to the mix. I think my best bet is to select a Toto and hope it does better than a Kohler.
Current toilet is: 10 in rough in, round bowl (about 17.5 in), and 17 in height (assume ADA).
Thoughts: kind of like the 1 piecers, would prefer to do my own tank innards repairs myself, yes to soft close seat.
It seems to me I may want to stick with a 1.6 flush vs a 1.28 flush since I assume more water hedges my bet for a better flush long term. Based on TerryLove threads it seems the Drake (Drake II) or Ultramax (Ultramax II) may be best choices. I looked at Totos site and the filter for 10 in rough in gives me 0 results but I do see 10 in rough ins within some descriptions. Can someone suggest the model #s and such that might be best for my situation? Is there a toilet I am overlooking?
I really want the toilet to end all toilets.
Thank you..
You might make sure the existing toilet is being refilled to its bowl limit.
You still might want a new toilet, but in the mean time, make sure the refill hose is pointing down the overflow and the fill valve delivers enough refill.
If the remodel is not changing the location of the toilet rough, these are the Toto choices: https://www.totousa.com/products/toilets#filters=rough-in:10150000000026367712
Strong son
Virginia
I definitely am going to replace it. The refill hose is in correct place.
I notice that the Drake CST744SF(R).10 (https://www.totousa.com/drake-two-piece-toilet-16-gpf-10-rough-in-elongated-bowl) shows that from the wall to the front of the toilet is 28 1/8 inches. This toilet seems to only come in Elongated. My current Kohler is a round bowl (or that is what the plumber said) and seems to have about an almost 2 inch gap between the tank and the wall and the distance from the wall to the front of the bowl is 28.5 inches. Looking at Kohler specs for the Cimarron they show about a 2 inch gap between the tank and the wall.
So my question is how accurate does my 10 in rough in have to be? Is it likely a Drake will not fit against the wall?
The toilet I have now is about as long (from wall to end of toilet).
Thanks
https://terrylove.com/pdf/cst744ef.10.pdf
shows about a 7/8 gap if the rough is 10. You can slide things a bit during install. If the wall and floor are not at right angles, that can affect things too. Use shims to adjust the angle if needed.
Position the shims when you dry-fit the toilet. Lift the toilet, place the wax, drop the toilet. Or maybe use waxless, and reposition as much as you want.
The Drake II needs 11.5" to set.
The 10" rough bowl would be the C744EF.10 which can come with either the 1.6 or the 1.28 gallon tank in the ST743 series.
A 1.6 version of that would be CST744SF.10
A 12" rough-in is 12" from the wall to the center of the drain.
A 10" rough-in is 10" from the wall to the center of the drain.
Please verify your actual rough-in. With 2" behind the toilet, they may have used a 10" rough toilet on a 12" rough-in flange!
The way to measure is from the center of the flange, often the toilet hold-down bolts to the finished wall (not the baseboard). Once you know that number, you can then decide what will fit.
Strong son
Virginia
Thank you all for your helpful assistance with this most needed yet most delicate house hold device.
Strong son
Virginia
I had the 10'' 1.6 Drake installed last week. Yet to put it to the test but I am hoping for the best.
Update 1
About 3 months later there have been no problems. I read Terry's review that the
wash/rinse of the bowl in this toilet is not the best. I agree. If that is the only problem over the next 10 years then I am fine with that. I also like the toto soft close seat. It is more comfortable than the one on my other toilet and it also seems to me this toilet has more room between front of the seat and where the human body starts.
Update 2
Well we had a plug. I suspect paper being rolled into a ball. Not quite sure. So I got the plunger (I threw away the other 3 I had) and cleared it. Well got about 6 months with no clog. I will say that unclogging this toilet was a no-mess adventure. The Kohler the plunger never fit quite right and always splashed water out of the bowl. This toilet the plunger fit nicely and no splash.
Strong son
Virginia
Hi Again,
Been about 6 years since had the TOTO. No plugs no problems. However we have hard water and not so great at cleaning the toilet.
So I would like to replace it with the same model. I installed the ones Terry and others noted above. The box the bowl came in is attached. I did buy the 1.6 GPF tank (but don't have pix of that box)
Appears they have gone to Vornado flush (which may be better since existing TOTO does not always clean the bowl).
Would this bowl and tank be the equivalent replacements for what I have?
The CST776 has a better bowl finish and the rinse swirls around the bowl. It's a big improvement over the CST744 that you had.
I sell a lot of those. My son just installed on in his Silverdale home.
The correct tank for the 776 bowl is the 776 tank.
ST776SA for 1.6 and ST776EA for 1.28
I would not get the CST746.
Thanks Terry! I will get the CST776 bowl and the 1.6 gpf ST776SA tank.
I think these are the two items you listed.
Yes, that should be it. They did leave a reference there to the 746, but the other numbers are the correct 776.
Strong son
Virginia
I received my new bowls. I notice in one the opening seems clear for the tank water.
But the other has a build up of porcelain. Is this something I need to worry about?
Thank you
They both will work fine. It's time to install them now. I love how they work. My son Taylor just installed one in his Silverdale home. He got rid of one of the round bowl contractor grade toilets.
Strong son
Virginia
Excellent. I know its time to install them!! Here comes the pain and suffering part ;)
