Wiring an Electrical Outlet to Pump Pressure Switch
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by asmart82, May 9, 2012.
  1. asmart82
    asmart82 New Member
    Jan 26, 2011
    East Orlando FL
    If I have a 3-wire pump, where would I connect the wires for the outlet inside the pressure switch so that the outlet only has power when the pump is on or would I be better off wiring it to the control box?
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    120v or 240volt outlet.
    It can be done but may not be safe, and may not meet code.
    What is this Outlet going to be used for ?
  4. asmart82
    asmart82 New Member
    Jan 26, 2011
    East Orlando FL
    I believe it is 240v, not sure but I can check. The outlet is going to be for a Stenner Chlorine pump.
    I had the pump hooked directly up to the pressure switch but I would prefer to have it hooked to an outlet and I prefer not to buy a flow switch.
    Here is a diagram for what I am trying to do but I am not sure which wire is which in the diagram. http://www.cleanwaterstore.com/technical/water-treatment-guides/Chlorinators/Stenner_chlorinator_startup.pdf
  5. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    All of the needed info is in the PDF file.
    It would connect to the same output / switched connections on the pressure switch as your Well Pump.
    If you do not understand the info in your PDF file then you may want a professional to help you.
    Be careful playing with electric.
  6. asmart82
    asmart82 New Member
    Jan 26, 2011
    East Orlando FL
    I've got the outlet hooked up. The chemical pump works only when the well pump is on but the power alternates on and off randomly for the chemical pump. Any idea what might be causing this? When I hook the pump up to a normal outlet, it is always on as it should be.
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    If it is not wired to the proper voltage it may be tripping the pumps internal overload protector.
  8. asmart82
    asmart82 New Member
    Jan 26, 2011
    East Orlando FL
    You were correct. It was a 120v pump on a 220v outlet. Bought a 220v motor and it fixed the problem. Thanks!
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Nice that you got it working.
    Enjoy.
  10. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    You could have made the 115 volt pump work. Just needed one wire to the pressure switch and the other to ground.
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That is what I would have done. Or run a new wire with a neutral.
    But to meet code it would have to be connected to a neutral, because it would be a current carrying conductor.
  12. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Don, NO, I don't think you would have connected that wire to ground. I don't know why you even joked about it.
  13. valveman
    Mar 15, 2006
    Lubbock, Texas
    Doesn't the neutral go to the ground bar? Or am I mistaken? :)
  14. BobL43
    Mar 25, 2011
    Long Island, NY
    Yes, (at the service panel) and that's the ONLY place where they are in effect connected to each other.
  15. valveman
    Mar 15, 2006
    Lubbock, Texas
    Thanks Bob!
  16. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I was not joking.
    That is how my 120V heat tape gets power from my Well pump switch for the winter.
    It may not meet code but it works for whatever I want to plug into the 120V outlet.
    Code is for City Slicker folks. We just Git-R-Done on the City Slicker Farms in Texas.
  17. BobL43
    Mar 25, 2011
    Long Island, NY
    Yes it will WORK. Keep the foil hat on, and you will be safe, I know because I wear one:rolleyes::p
    OK, now I understand why the Midwest and wild Wild West have so many lightning storms. Lightning currents start from the ground up to the clouds that are stripped of their electrons and need to be replenished by the abundance of them spare ones in Texas just jumping around the place looking for a new home:cool: And I just realized what makes those Texican/Mexican jumping beans jump too:p
  18. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That is true, but new NEC codes (BR549.1234.0987) don't allow a ground conductor to carry current in a Normally operating mode, It is for a fault and safety only.
    The most important code is Morse Code.
  19. BobL43
    Mar 25, 2011
    Long Island, NY
Similar Threads: Wiring Electrical
Pumps and Tanks Well Forum & Blog. Water is life. Solenoid valve and Float switch Voltage, wiring? Feb 21, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Chlorinator and Storage Tank Wiring Jun 22, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Need wiring diagram verification... Aug 5, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Wiring submersible pump Jul 31, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Wiring Well Pump May 2, 2015
