Will PVC bond to CPVC?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Flipperman2a2w, Mar 17, 2011.
  1. Flipperman2a2w
    Flipperman2a2w Member
    Feb 25, 2011
    North Carolina
    I have a 3/4" PVC to 3/4" CPVC adapter. I know that I have to use CPVC cement (as PVC cement is not strong enough to work on CPVC).
    Having said that, will CPVC pipe actually bond to PVC? I assume it would, since they make an adapter for that very purpose. The slip adapter itself is made of PVC.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Many folks do not understand about how the various plastic pipes are joined. There are 3 basic kinds of plastic pipe; ABS, PVC, and CPVC. They are chemically different. That much is easily understood. The problem comes in the fact that what we all commonly call pipe "glue" or "cement" is neither of these. They are solvents that melt the top surfaces of the pipe and fitting briefly. When the two surfaces are joined, the liquid surfaces combine into what is actually a chemical weld. So, it's not a matter of bonding, strength, or sticking. Each type of pipe has its own solvent, so the answer to your question is, No, you can't join different types of plastic pipes, except by using appropriate adapters. Not known what you are doing and why you would need to join CPVC to PVC, it's hard to advise you on what you may need to do. A couple of problems with PVC and CPVC pertain to why you are mixing media and size incompatibility. In other words, 3/4 PVC is not the same size as 3/4 CPVC.
  4. PM5K
    PM5K Member
    Oct 9, 2006
    San Antonio, TX
    I thought CPVC was typically used for supply lines and PVC for drains and vents?
  5. Flipperman2a2w
    Feb 25, 2011
    North Carolina
    Here's my situation. . .
    The water line that comes into my garage from underneath the house is PVC. I'm installing a water filtration system, and I want to add a brass hose bib to the PVC line before it goes into the filtration system (that way I can draw unfiltered water for yard maintenance).
    This is how I want to install the hose bib: 3/4" PVC main line -> 3/4" PVC to 3/4" CPVC adapter (this adapter is specifically made to transition 3/4" PVC to 3/4" CPVC) -> 3/4" CPVC pipe -> slip CPVC/threaded brass transition adapter -> brass hose bib.
    I considered using a brass hose bib with PVC, but I know you're not supposed to use a male brass thread with a female PVC thread. So, I ultimately want to use the CPVC/brass transition adapter to attach the hose bib.
    Here's what I don't understand. . . Why would they specifically make an adapter for PVC to CPVC if there's no way you can successfully join the two materials?
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    They are not commonly found in stores, but such a transition fitting normally has a brass nipple between the 2 types of plastic. There are also plastic fittings with brass or stainless steel threaded inserts.
  7. Inspektor Ludwig
    Inspektor Ludwig Journeyman/Inspector
    May 11, 2006
    In the good ol' UPC
    Get a male pvc coupling and a female copper thread by cpvc adapter and screw em together to transition.
  8. Laurihill
    Laurihill New Member
    Dec 20, 2012
    Mn
    I need to find an adaptor that will tie 3/4 inch PVC to 3/4 inch CPVC. Is that a common adapter? I can't come up with a connector....
  9. Terry
    Aug 17, 2004
    PVC and CPVC don't mix. Inside a home, only CPVC is legal. PVC is for cold water pipes underground.
    Since they are not the same size, the only way to connect the two pipes is with threaded fittings. The post above by the inspector mentions that.
  10. hj
    IT would only work, and be "legal", if the two sides were different materials so their proper primers and glues could be used on each side.
Similar Threads: bond CPVC
Plumbing Forum, Professional & DIY Advice Bonding question for new water supply line Feb 18, 2012
Plumbing Forum, Professional & DIY Advice WHat can I use to bond PVC to brass/copper? Dec 4, 2011
Plumbing Forum, Professional & DIY Advice Copper pipe grounding/bonding - how to? Dec 29, 2010
Plumbing Forum, Professional & DIY Advice bonding/grounding and pex Oct 22, 2009
Plumbing Forum, Professional & DIY Advice Metal Bonding? Aug 3, 2007
