Why plumbers putty on base of toilet??
Discussion in 'Toilet Forum discussions' started by stash, Sep 29, 2005.
  1. stash
    stash New Member
    Sep 29, 2005
    I know this may be a strange question but here it goes. Why do you put plumbers putter around the base of the toilet when you install it? I think if there was a leak around the wax ring and the plumbers putty was used it would seal in the water and cause the floor to rot around it. Without the putty the water would come out from the base of the toilet and you can then see the leak and fix it. Comments?? Thanks Stan
  2. Terry
    Aug 17, 2004
    That's why in some areas, the inspectors insist that you don't seal all the way around the bowl.
    Trapped water under the bowl can cause rot.
    I don't use plumbers putty either.
    It has oils that will discolor some floors.
    I prefer something like PolySeamSeal.
    [​IMG]
  4. PlumberWannabeJr
    PlumberWannabeJr New Member
    Sep 15, 2005
    I agree with Terry
    Terry is right. I read from books that you may want to leave behind unsealed, just in case there is water leakage down below.
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    grout
    I found that toilet manufacturers don't make toilet bowls that won't wobble and when you couple that with a ceramic floor that's hard to get perfectly level, you do have to shim and grout, not calk, to make the setting of the toilet solid. I prefer to come close to the color of the grout in the tile.
  6. Kristi
    Kristi Tradesman Plumber
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    can't get the wobble out? I loosen the bolts, jam pennies around different points that can fit them and cinch the toilet down again, works every single time... and I sometimes leave them uncaulked, sometimes the owner specifically asks for none...
    I've never put plumbers putty under there!
  7. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    plumber1
    Who uses plumbers putty?
  8. Kristi
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    I don't know, who uses plumbers putty? I might have commented on that from Stan's original post... :eek:
  9. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    wobble
    Pennies are temporary unless you grout right away.
    If you want a good finished job I think you should grout and not calk, unless it's a job that gets inspected and is required.
  10. hj
    putty
    "Decades" ago plumber's putty was used to set the toilets, like the wax rings are used now. But even then the putty was not used to seal around the base of the toilet. It does not bond to the toilet and floor, nor does it harden up within any reasonable time, so it will not prevent "wiggles". It can stain the floor and will discolor over time.
    [​IMG]
    Here, the inspectors specifically look at the bottom rear of the toilet to be sure that spot was not left uncaulked.
    [​IMG]
  11. RBrown
    RBrown New Member
    Sep 18, 2004
    West Virginia
    Putty
    My plumber used putty instead of a wax ring to set my Champion toilet. So far so good.
  12. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    putty
    Putty will do in a pinch.
    But what plumber won't have wax rings on the truck?
    I think that you were short changed.
  13. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    Often a bead of putty on top of the wax ring will be used to ensure a good seal. This is different from using it to set the base of the toilet.
  14. Snowman
    Snowman New Member
    Mar 17, 2005
    Retired math teacher
    FLORIDA
    BINGO!! I learn things everyday on this forum. Never thought of that... Thanks,
    Regards, Tom :)
  15. Terry
    Aug 17, 2004
    Wax is supposed stick to the bottom of the toilet. That's why they don't glaze the bottom of toilets.
    I don't really see why wax wouldn't be used, since it does such a good job of sticking to the toilet.
  16. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    putty
    Putty certainly won't help and will hinder a good seal.
    I would never do that.
  17. hj
    seal
    IF the gap between the toilet and flange is the correct distance, then using putty will not accomplish anything and may defeat the purpose of the wax seal. It will not adhere to the toilet and the oil in it will prevent it from sticking to the wax. When the toilet is placed in position, the putty will either spread out if it is soft enough, or indent the wax if it has slightly hardened. But in either case, the amount of material between the flange and toilet will be the same, regardless of what that material is.
  18. Snowman
    Snowman New Member
    Mar 17, 2005
    FLORIDA
    OK.............. cancel the tip about using putty on the wax ring. Thanks..... :)
  19. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I am constantly pulling up old toilets in my area where plumber's putty was used under the toilet as a rule, not the exception. I always use wax rings without the horn built into the ring.
  20. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    OK, what IS the correct distance?
    Does this "correct distance" vary with the toilet, wax ring, etc.?
  21. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    putty
    If you need more thickness, just reach down and pinch the seal to make it stand a little taller or take a second seal and slice off as much as you need.
    You need some excess wax.............
Similar Threads: plumbers putty
Toilet Forum discussions Plumbers putty between tank and bowl Jul 18, 2006
Toilet Forum discussions For Plumbers: Aug 29, 2009
Toilet Forum discussions A New Resturant not just for Plumbers Oct 26, 2007
Toilet Forum discussions Whats the answer to this question? Many plumbers, all different answers Mar 3, 2007
Toilet Forum discussions please help non-plumbers with running toilet Feb 24, 2007
