what causes pipes to do this????????
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by detroithomeinspector, Oct 10, 2005.
  1. detroithomeinspector
    detroithomeinspector New Member
    Aug 30, 2005
    Home inspector
    Detroit Michigan
  2. hj
    joints
    Usually bad solder joints. Not bad enough to leak, but bad enough to seep water and when it evaporates it leaves the minerals behind. But it could be excessive flux on the joint, although flux is usually "burned" off during the process of soldering the joint.
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    pipes
    It started out as sloppy soldering.
    The pipes were never wiped at that time of soldering.
    Sweaty pipes over several years will look like that.
    And some of those spots will develop pin holes.
  5. detroithomeinspector
    Aug 30, 2005
    Home inspector
    Detroit Michigan
    detroit home inspector
    i agree that some of those spots will develop holes...but why does that happen??
  6. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    See HJ's and plumber1's comments above -- flux wasn't properly wiped off at time joints were made and it can be corrosive over time (as I understand it).
  7. Gary Slusser
    Retired
    The spots in line on the underside of the tubing is from water droplets caused by humidity and 'sweating' pipes. I've never seen them lead to leaking. But flux that is acid based, and left on the copper, eats holes in the tubing and provides an excellent place for bacteria to live; which have an acidic waste, and both cause pinholes in copper tubing. Non water soluble flux happens to be the second most common cause of pinholes in copper tubing. The first or most common cause is not reaming the end of tubing that has been cut off with tubing cutters which allows for erosion corrosion caused pinholes.
    The white/gray residue is caused by water from 'sweating' corroding the solder; especially lead based solder.
    Gary
    Quality Water Associates
Similar Threads: causes pipes
Plumbing Forum, Professional & DIY Advice hand shower causes knocking/vibration in pipes Jul 19, 2008
Plumbing Forum, Professional & DIY Advice Neighbor turning on her outside faucet causes noise in my water pipes Jul 13, 2008
Plumbing Forum, Professional & DIY Advice Found a new drip. Causes? Oct 13, 2016
Plumbing Forum, Professional & DIY Advice What causes 3 separate leaks to occur at the same time? Aug 28, 2016
Plumbing Forum, Professional & DIY Advice What causes brass piping to disintegrate like this? Feb 19, 2016
