DYIWeller
I don't understand, new management or lighter product?IMHO Franklin today is not the same Franklin of yesterday. I think a lot of pump manufacturers are riding on the Franklin reputation.
This fab tool set; it hold a section of drop pipe as its getting pulled up, and this Fab tool set, is used for the disassembly of a section of pipe from leaning over and for support?I took a 6" coupling and machined it to drop over 6" casing. It has a socket on the side to hold a 1" piece of steel pipe 16' long which has a hoop at the top to contain the drop pipe. You can probably do the same thing for your 4" casing.
Good advice. I will lower the pitless adapter.You can certainly put more fill around the well, but I would rather see a new pitless installed and the line buried deeper.
What would be the recommended pump height for a 1 HP 10-15 GPM well pump?I'm not really understanding why the pump needs to be set so low with that much recovery but then I'm not a pumpman. Just seems like a lot of pump, a lot of wire, and a lot of pipe.
