Wax Rings Are Too Small or Too Big
tesla
DFW (Garland), TX
When the toilet flange is flush with the floor it seems that 2 wax rings might be too much and 1 ring might be too little. Which would be the better solution? Also, are 2 standard wax rings the equivalent of 1 number 10 ring? In addition, I have a number 10 wax ring with the horn. Anyone ever remove the plastic horn from the wax successfully and used the wax ring?
ShockHazard
North East Pennsylvania
I always use the extended size aftermarket types, and throw the stock one away.
If you used two, theres a risk one would simply split and you wouldn't know about it for months.
I still don't know why we use these primitive contraptions.
WJcandee
Wise One
New York, NY
2 standard is more or less a #10.
Don't try to remove the horn.
More is better. Unless it's grossly too much, it'll just squish around the base. With the flange level with the floor, go with the 2.
Gary Swart
Yakima, WA
When you say the flange is flush with the floor, I take that to me the flange is slightly recessed into the finished floor. If that is the case there are a couple of ways to deal with the problem. First, use 2 standard size wax rings. the top ring can be the funnel type. A single jumbo thick ring would likely be OK, and a waxless seal would also be OK. Don't try to save $5 or so by removing a funnel from a wax ring.
tesla
DFW (Garland), TX
The flange is not on top of the floor but is flush with the floor since the tile was tiled around it.
I'm unable to find anywhere a jumbo ring without the plastic horn. Fluidmaster and Oatie and another did not have one listed on their website either.
Is their no concern about too much wax oozing into the waste pipe?
So if 2 rings are the ideal in my situation it would be first standard ring would be rounded side down on the flange, 2nd standard ring with horn on top of that with flat side down on the flat side of first ring. That about right?
Another question regarding shims. I understand you dry set the bowl without wax and determine if it needs to be shimmed and place the shims. Are you guys leaving the shims on the floor when you reposition the bowl onto the wax? Don't the shims move out of position?
tesla
DFW (Garland), TX
Another issue has come up. The flange is uneven with a rise to the right. Not a big issue except for the floor is unlevel with a rise to the left which has caused this.....
20130303_163421
See how much the level is elevated over the floor on the right side compared to the left. If I drop the bowl down without shims, it is planted with very little rock to it If I shim the bowl to level it, it has a large gap on the right and tends to rock unless I shim 3 points and also appears to be elevated more so over the sewer pipe.
20130303_162314
Any ideas? Also, can I take a bit of wax off another wax ring and build it up to take up the space on the unlevel flange if I should need to do so?
When the flange is high like that, you may want to use a single wax without horn.
I would rather see that bowl on the floor then on shims.
If you feel you need more wax, you can cut and paste. (I mean just squish more wax on)
If I ever shim a bowl that rocks, it's at the back pinning the front of the bowl to the floor.
I don't worry too much about side to side or if the floor slopes. I would rather have the bowl on the floor without gaps.
We did install a bowl the other week with a horrible slope on the tile floor with a bend to it. I shimmed and told the tile guy to do his grout thing on it. Not a nice looking job.
It depends on how out of level the floor is...if it's not too much, just set the toilet and don't worry about the toilet being slightly out of level. If you sit on it, and it feels funny, then it's time to shim it level.
tesla
DFW (Garland), TX
Want to thank you guys for your help. I wound up putting the bowl down without shims and it is solid with no rocking. However, it is unlevel by 1/4 inch.
Thanks again. This is got to be the most helpful and friendly forum that I've experienced.
