WaterSense Toilet with 10" rough in
ju1iana
Raleigh,NC
I've been researching WaterSense toilets for a few weeks now and had finally decided to order the Toto Eco Drake. Then I checked my rough in measurements and found that I have a 10" rough in (actually 9.5" from finished wall to drain center).
I've been checking and so far have not found any WaterSense rated toilets with a 10" rough in. Help!!
If no WaterSense rated with a reasonable price - I'd also appreciate 1.6 GPF toilets as well. I'd like to see all my options.
Thanks in advance!
-julie
Go to www.totousa.com and search on UniFit. Any of those will use 1.6g, and while it comes with a UniFit for a 12" rough-in, (you'll end up throwing it away), you can also buy a UniFit for a 10" rough. Most of the toilets that use the UniFit have 3/4" behind them, so you'd still have a little space with your 9.5".
ju1iana
Raleigh,NC
Thanks Jim.
That's good to know the UniFit would be an option.
Unfortunately, I need to get something cheaper than that. Around $300.
I'm so disappointed to find I need a 10" - always something to complicate my projects!!
10" Toto Drake toilets.
They only need 9-1/4" to install.
CST744EF.10 or CST744SF.10
Comfort height, elongated bowl with either the 1.28 gallon Watersense Eco Flush
or the 1.6 gallon G-Max flush.
https://terrylove.com/pdf/cst744ef.10.pdf
TOTO now has a 10" dual flush at the factory.
I'm bringing some here for the Seattle area.
CST412MF.10
