What do you mean by optimum? Would you like to set it to use a little less salt? Zero hardness is not bad. Start using less soap.Here are the numbers on this setup. The softened water tests at zero hardness. I suspect it is over softened. How does one fine tune the system for optimal performance?
Pour in as many bags as you like, and lift the lid and look often enough that you don't let the salt fall so low that it is all below water. I don't fill my brine tank full, but I look maybe once per month. Some fill higher. I think that when new, it might be good to watch how it goes, but that is not necessary.System info
salt lb/cuft on't know how to set this up and how many bags of salt and how often should be added ;
This is not a number that you enter into the softener, but it is a number used in calculation of the brine fill BF and the capacity C. 6 is at the lower end of the salt usage commonly used. Actually, this may be a flaw in the numbers I posted. My BLFC is 0.125. I don't know where I got the 0.25 number for yours, but it is a reasonable number. Looking back, I don't see where you posted that. If there is no other indication, it would be good to ask your dealer what yours is. There are other ways to learn the number.A
BLFC : Not sure how to set this up ; Brine Refill rate GPM
Finding out the BLFC is your action item.
You don't need to figure out the number. With the settings I listed, the softener will watch your usage and come up with a number. It may take a couple weeks, because it can be pessimistic initially. If you want to enter a reserve capacity yourself, you can. I did that with mine.cubic ft resin : 2.5 ; Same as (nominal grains/32,000)
Raw hardness : 21 ; including iron etc
Estimated gal/day 240.0 ; 60 gal per person typical calc
Est days/regen Don't know how to figure out. I don't think this meter can track this data. I would like it to regen every 14 days. ; presuming days each use reserve capacity
That estimated days was just an estimate and is not programmed in.
To meet your wish for 14 days, change DO (day override) to DO=14. That puts an upper limit on the time between regenerations. If you use a lot of water, regen will happen sooner.
But why 14 days? If you are away or just using less water, why not let the time go longer like up to 28 days? The metering will watch when you have used enough water that you should regenerate tonight to avoid running out of hard water tomorrow.
