Water Pressure to Shower Head in Tub/Shower is Low
Milanomike
Cincinnati, Ohio
Hi Guys,
Need some help here, 10 year old Am Std pressure balance tub/shower kit (pressure balance valve R120 or R125 series). Diverter valve leaked really bad, little water to shower. Replaced spout/diverter valve, no more leaking at spout, good!. However, pressure to shower head is only a bit better. Disassembled and cleaned shower head, seems fine; however, pressure at shower head with no head on it is not great, water should shoot out of there at decent pressure. By the way, not a "big box" unit, learned long ago to buy this stuff at plumbing supply place.
Took cartridge off and it looks fine, should I just replace it?
Was wondering is I should completely disassemble pressure balance unit. There is a plastic piece with an o-ring in the manifold, not sure if this comes out, did not want to break it. I think I completely disassembled when I soldered this thing in during remodel 10 yrs back, but can't recall for sure. Can this be completely disassembled and cleaned? Seems like I want to make sure manifold is not plugged/clogged, right?
Other options, don't really want to tear into this, but daughter needs shower to work.
Thanks for any help in advance.
Mike
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Has the volume of water out of the tub spout changed since you "fixed" it? If you are now getting less water out of the spout, then there is a high probability that some crud got stirred up and is now affecting the pressure balance cartridge. The spout and the shower share the same supply and cartridge.
Milanomike
Cincinnati, Ohio
No, water pressure/volume to tub is fine before and after. It's the pressure to the shower that is considerably lower. Guess I could swap shower heads from the other bath to make sure it's not the shower head. Will report back.
Milanomike
Cincinnati, Ohio
Duh, just switched ancient shower head from other bath to the problem shower and guess what it seems fine! OK, off to buy a new shower head.
