Water Pressure to Shower Head in Tub/Shower is Low
Discussion in 'Shower & Bathtub Forum & Blog' started by Milanomike, Mar 9, 2013.
  1. Milanomike
    Milanomike Member
    Nov 28, 2006
    Cincinnati, Ohio
    Hi Guys,
    Need some help here, 10 year old Am Std pressure balance tub/shower kit (pressure balance valve R120 or R125 series). Diverter valve leaked really bad, little water to shower. Replaced spout/diverter valve, no more leaking at spout, good!. However, pressure to shower head is only a bit better. Disassembled and cleaned shower head, seems fine; however, pressure at shower head with no head on it is not great, water should shoot out of there at decent pressure. By the way, not a "big box" unit, learned long ago to buy this stuff at plumbing supply place.
    Took cartridge off and it looks fine, should I just replace it?
    Was wondering is I should completely disassemble pressure balance unit. There is a plastic piece with an o-ring in the manifold, not sure if this comes out, did not want to break it. I think I completely disassembled when I soldered this thing in during remodel 10 yrs back, but can't recall for sure. Can this be completely disassembled and cleaned? Seems like I want to make sure manifold is not plugged/clogged, right?
    Other options, don't really want to tear into this, but daughter needs shower to work.
    Thanks for any help in advance.
    Mike
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Has the volume of water out of the tub spout changed since you "fixed" it? If you are now getting less water out of the spout, then there is a high probability that some crud got stirred up and is now affecting the pressure balance cartridge. The spout and the shower share the same supply and cartridge.
  4. Milanomike
    Milanomike Member
    Nov 28, 2006
    Cincinnati, Ohio
    No, water pressure/volume to tub is fine before and after. It's the pressure to the shower that is considerably lower. Guess I could swap shower heads from the other bath to make sure it's not the shower head. Will report back.
  5. Milanomike
    Milanomike Member
    Nov 28, 2006
    Cincinnati, Ohio
    Duh, just switched ancient shower head from other bath to the problem shower and guess what it seems fine! OK, off to buy a new shower head.
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Good luck. The environmentalists got rid of most of the good ones.
Similar Threads: Water Pressure
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Occasional Low Water Pressure Jan 19, 2016
Shower & Bathtub Forum & Blog Concern of water pressure on well for dual shower head setup Dec 5, 2015
Shower & Bathtub Forum & Blog Tub Water Pressure Help... Sep 28, 2015
Shower & Bathtub Forum & Blog Drop in water pressure when flushing toilet Jul 18, 2015
