web_surfer
In past posts on this forum I believe the general consensus is that a PRV is not needed if water pressure is under 80psi.
A couple of months ago the new copper plumbing was completed - all type L. 1" from meter to water heater & 3/4" after that to various locations that then divide off into 1/2" for individual fixtures. Used soldered on Nibco ball valves. Also, based on reading this forum the weak points are the connections to fixtures, faucets, etc. Fixture connections are made using Nibco Pro-Stop 1/4 turn compression valves & Watts stainless braided hoses (not the FloodSafe hoses).
With the new plumbing in place the pressure is right around 76±psi, with peaks up to 85± psi. Have a pressure gauge installed in line right after the meter. City says this is normal.
Given this information would it be a good idea to install a PRV & expansion tank? I am leaning towards it - would be more comfortable with pressure in 50 - 60 psi range.
Any suggestions as to a good quality, reliable PRV?
Thanks,
Matt
Thanks,
Matt
