I am planning a remodeling project which will add 2 shower equipped bathrooms (3/4 baths). Based on the Uniform Plumbing Code meter sizing table 6-6, I can get by with a 1" building supply and a 3/4" meter (based on total fixture unit load and maximum allowable developed length.) Water pressure at my house is high - 87#.
My problem is that I have a 5/8" meter with 3/4" couplings, with a 3/4" city service line, and a 1" copper building supply from the meter to the building, but our city does not install 3/4" meters - only 5/8" meter then the next size is 1" meter. To go up to a 1" meter the city wants about an additional $5000 charge up front (covers the cost of adding a 1" city service line from the main to the new 1" meter, breaking/replacing the pavement, capital cost for the system, etc.)
Two questions:
1) Is a 5/8" meter really a "nominal" 3/4" meter in the Uniform Plumbing Code chart (since I see no 5/8" meter listed there)?
2) Is there somewhere I can get the mathematical formula that UPC uses to make the chart, and possibly demonstrate to the city that I would have enough volume/pressure with a 5/8" meter and 1" building supply line and my big 87# pressure - still meeting UPC requirements?
(I would imagine that the formula would take into account friction loss on the pipe over a given distance, city pressure, fitting friction loss, etc. Even with an actual 5/8" "restriction" at the water meter, I would think that the additional volume in a 1" building service and main trunk line would compensate for the 1/8" loss at the meter (3/4" - 5/8" = 1/8" less). I could even increase the size of the trunk line inside the building to 1 1/2" or so to add additional volume in the system. I'll bet 100' or so of 1 1/2" of PEX would not cost $5000.
Thanks
Two questions:
Thanks
