Water hammer-Clunk
Discussion in 'Toilet Forum discussions' started by snowbird0103, May 23, 2006.
  1. snowbird0103
    snowbird0103 New Member
    Sep 27, 2005
    Retired
    I have a toilet in the Master bath that has a clunk(pipe rattle) after the tank is full and shuts off :confused: . It has a flowmaster 400a and I cleaned it to be sure there was no restriction. The inlet valve is open all the way. If I partially close the inlet there is no clunk but there is water hammering. The toilet 19 years old.
    Will I have to cut a hole in the wall behind the inlet pipe and secure the pipe better? Or do I need to replace the inlet valve?
    Any advise would be appreciated. Thanks in advance
  2. lmoyer
    lmoyer New Member
    Apr 29, 2006
    I have had the same problem and found the fix to be replacing the fluidmaster value in the tank with a Korky value fix the problem. They do not cause water hammer.
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    clunk
    Start by chainging the ballcock......
  5. hj
    clunk
    Go to HD and buy a Fluidmaster replacement cap and snap it on in place of your old one. But first observe your Fluidmaster when the clunk occurs. If the upper portion "jumps up" when it clunks then you need a new valve.
  6. Terry
    Aug 17, 2004
    You can repair the Fluidmaster, but if you want less hammer, put in the Korky Quietfill.
Similar Threads: Water hammer-Clunk
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Saturday at 9:53 AM
Toilet Forum discussions Kohler Wellworth Cannister - Water won't fill tank (seal is new) Feb 20, 2017
Toilet Forum discussions Toilet Water Gets Gone Feb 1, 2017
Toilet Forum discussions Better Toilet for Hard Water/Iron Conditions? Jan 30, 2017
Toilet Forum discussions Toilet water supply has been off a while...try to turn back on now and get a horrible loud noise... Jan 18, 2017
