goknights
I am an amateur diy'er who has never worked with PVC before. My project is to lay floor tile in my bathroom. I removed the linoleum and am down to the sub-floor. I saw that the toilet flange was screwed directly into the sub-floor, and my research told me that it should be placed on top of the finished floor so I set out to remove the existing flange with a chisel so I could glue in a new one after I laid the tile.
Long story short, I severely damaged the waste pipe and only partially removed the flange (I stopped when I saw how much I had cracked it).
I'd appreciate some advice on what my next step is. Is the waste pipe in any way repairable or do I have to cut the whole thing out and replace it all. If I have to replace it all, where do I cut exactly and how would I go about putting in a replacement piece?
I have included a shot of the waste pipe coming out of the floor and a reverse angle so you can see just how much I damaged it. I also included a shot of what lays beyond the opening. I'm guessing that smaller pipe joining in from the left is from my shower drain.
Thank you in advance for your help.
