Washing machine / laundry tub plumbing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bradatkins, Nov 4, 2010.
  1. bradatkins
    bradatkins New Member
    Nov 4, 2010
    Canada
    Hi -
    I'm looking at dry walling my basement walls in my laundry room. Before I do that, I wanted to make sure what I have is OK.
    If it's not, any suggestions to clean it up if necessary would be appreciated.
    Brad
  2. Terry
    Aug 17, 2004
    Are you putting a vent on the laundry tub trap arm before it enters the stack? The vent should be vertical until it's above the standpipe for the washer.
  4. bradatkins
    Nov 4, 2010
    Canada
    Hey Terry -
    Currently the vent comes into the p-trap arm (ie at the end of the ptrap) horizontally (ie not from the top).
    Are you saying that the last section of the vent pipe that's running horizontally needs to come in vertically on the p-trap arm?
    I've attached another diagram. My apologies if I'm not understanding correctly.
    Thanks for your patience.
    Brad
  5. jimbo
    jimbo Plumber
    A vent pipe can not be horizontal ( lower than 45º) until it is 6" above the rim of the highest fixture...the sink or standpipe. By convention, we use 42" above floor level for that reference.
  6. bradatkins
    Nov 4, 2010
    Canada
    Ahh ok, so like the revised attached?
Similar Threads: Washing machine
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Washing machine wall box suds backing up. Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Washing machine inlet hose lifespan Dec 31, 2016
Plumbing Forum, Professional & DIY Advice Washing machine water feed shaking around Dec 31, 2016
