vibrating pipes..NOT Hammer
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dmorra62, Feb 3, 2007.
  1. dmorra62
    dmorra62 New Member
    Feb 3, 2007
    Hey people! Try this one on for size...Just replaced dishwasher. everything smooth. connected electrical, waste, water feed. started her up, ran like a charm. 4 days later (dozen or so washes) loaded her up hit the button and the water feed pipes start shuddering loudly. wont stop unless I cancel wash OR I turn on the hot water in sink faucet for a split second...then it stops. Happens everytime I do a Load now. Whats the deal? figure its pressure or something. Old washer ran for 14 years not a sound.
    thanks doug
  2. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    possible float valve problem? what's the water pressure to the house? Is there a check valve & expansion tank after the water meter or water heater?
  4. Racer814
    Racer814 New Member
    Dec 24, 2006
    if the dishwasher is being fed by a compression type stop valve, the washer may be "fluttering"..that can be fixed
    if not, try a in line hammer arrester on the water line to the DW
  5. dmorra62
    dmorra62 New Member
    Feb 3, 2007
    HAve all the check valves and expansion. Pressure set to 70lbs. Don't have any problems in the house with ANY type of noise/viration for 14 years. Nothing changed in the configuration.
    It has to be the washer inlet valve restricting flow. but why only on this washer and not on previous and why does vibration go away when faucet is turned on. don't even have to turn it on long a second or two clears the vibration. and then it fills fine.
    thanks
  6. dmorra62
    dmorra62 New Member
    Feb 3, 2007
    No compression just weltrol pressure tank at 70lbs. been like this for 14 years.
    I think hammer arrestor is designed for the opposite of what is happening. hammer is for when water is shut off at a valve and the pipes shakes due to hard stop from pressure.
    In my case the pipes shake when th water starts to flow and continues until flow stops.
    thanks
  7. Terry
    Aug 17, 2004
    I had a customer with the same problem, we put in an inline hammer arrestor and that helped.
    Also make sure the shutoff is fully open.
  8. dmorra62
    dmorra62 New Member
    Feb 3, 2007
    Doen't matter what position shutoff is at..tried all positions. Why after 4 days no problem then it started? Could the inlet valve solenoid be clogged or not opening all the way? I did take it off and blew through it. seemed clear. no restriction. however i blew through the out port. i could not blow it out the way the water goes in because the solenoid was in closed position (disconnected from electric)
    the water feed is a 3\8" flex copper tubing with compression fitting (flared with burrel?) how to put hammer in line?
  9. Terry
    Aug 17, 2004
    Sioux Cheif makes an inline using 3/8" compression.
  10. Randyj
    Nov 25, 2006
    Alabama
    dmora.... I had the same problem with a toilet. I swapped out the fill valve with a different type which stopped the noise which sounded like an air horn unless I opened a faucet until the tank filled and the valve shut off the water flow. That logically tells me that there was a difference in the force against the hickey thingy that stops the water flow. It appears to me that this is similar to your problem. I'd bet three nickles that if you lower your water pressure to about 45 psi that your problem will go away. Otherwise you might have to swap out that solenoid with one which is stronger to overcome the line pressure easier and faster. There is a couple of things called inertia and momentum which have to be overcome...water (an object) in motion so to speak has more force than an object sitting still (hold a 5 lb weight in your hand then try to stop it from moving when dropped 50 ft and you'll understand what I'm talking about).
Similar Threads: vibrating pipesNOT
Plumbing Forum, Professional & DIY Advice Loud Humming/Vibrating pipes Apr 19, 2016
Plumbing Forum, Professional & DIY Advice Noise from vibrating pipe. Jan 30, 2015
Plumbing Forum, Professional & DIY Advice Problem with hot water tap in shower vibrating and water sputtering Jan 21, 2015
Plumbing Forum, Professional & DIY Advice Pipes Vibrating So Bad that it Sounds Like an Old Motel Bed Vibrator! Sep 11, 2014
Plumbing Forum, Professional & DIY Advice vibrating pipes Jun 2, 2014
