nola000
Type of pump?
Submersible___Y_____
Two wire (no control)____Y____
Three wire (control box)___N___
Wire Size____12_____ Wire Length____100____
or
Jet Pump (above ground)____N_____
One or two pipes down the well__1__
Size of Pump?
Motor Horsepower?_____1_____
Pump Model #___4F19S10___________
Date Pump Installed____not yet______
Pumping from?
Cistern tank_____N______
Pond, lake, river____N____
Water Well______Y______
Depth of well_____300'_____
Depth to water____16'_____
Pump Setting_____80'_____
Pipe Size____1.25"_____
Drop Pipe Material
PVC____N____
Steel___N____
Poly____Y____
Well Recovery Rate____18?___gpm
Well Casing Diameter___4____”
Rock Well_____N_____ Sand Well_____Y_____ Other______________
Date Well Drilled_____March 2013_______
Well Casing Material
PVC____Y____ Steel____N_____ Other_________
Pressure Tank?
Bladder or diaphragm tank (one pipe to tank)_____N_____
Size or model of tank______HP-26______
Air charge in top of tank, with pump off and water drained______0______PSI
(check with car tire gauge)
or
Plain Hydro Pneumatic tank (two pipes to tank, one in and one out)____Y_____
Size of tank_______120_________
Pressure Switch Setting?
On 30, off 50 ____N____
On 40, off 60____MAYBE_____
Other_______45-65?________
Pump Control Method?
Cycle Stop Valve model #____CSV160_____
Variable speed control #_____N_____
Pump Start Relay (sprinkler timer, no tank)____N______
Manually turned on and off_____N_______
Pump Protection
Cycle Sensor____N_____
Pumptec______N_______
Low pressure cutoff switch (lever on side)_____N_____
Other_______N________
Filters or Softeners______N________
Before or after pressure tank_______
Type of filter___________________
Bypass available________________
Water Used For?
House Use____Y___ Number of baths___2____ Number of People____4____
High Flow Showers____2.5___gpm?
Plus/Or
Irrigation with timers____N____
Irrigation with hoses____N____
Heat Pump______gpm?
Do you have, and know how to use
an Ampmeter and Voltmeter________Y__________
Describe Problem__________________________.....
Hi. Looking for some input. Been reading a lot of similar threads but none that answered my questions. I think valveman could help me a lot if hes out there.
I just bought some equipment today to hook up my newly dug well. All my equipment...
Tank : Wellmate HP-26 - 120g, fiberglass, bladderless(air-over-water)
Pump : F&W Commander "S" - 1HP, 19GPM
Air Injection : Wellmate Micronizer
Pressure Regulation : CSV160
So the micronizer instructions say that the operating range for pressure is 10-60 PSI and the operating range for flow is 5-15GPM but dont I have to set my pressure switch cut-off to about 65PSI to get the CSV160 to operate properly, any problems with the micronizer being out of range at 65PSI? Will it damage the micronizer above 60 PSI or just not put water in? When the tank is drained down to say 45PSI and the pump kicks on will the micronizer put air in the water only until it reached 60PSI and is that enough air injection time for a 120G tank to prevent waterlogging?
The only way I could see the micronizer working in this scenario is if, and Im no hydrodynamicist so please correct me, when while the pump is running and the demand in the house is greater than 5GPM which is the minimum flow rate for the micronizer to work, pressure is held at 60PSI by the CSV160 which is the maximum pressure that the micronizer works at and then the bubbles(air injection) somehow go into the tank and not down the supply line to the house. I dont think this will work because during this operation the air bypasses the tank and goes straight to the faucets in the house. Is this not right? Then when demand in the house stops the CSV160 regulates the flow to fill the tank to 1GPM which isnt enough flow for the micronizer. So in theory the micornizer never injects air into the tank with a CSV.
If this is right then doesnt that leave no other scenario that allows a micronizer to work with a large capacity pump(>15GPM) and a CSV160? What equipment could I use that would allow me to utilize a CSV, a 19GPM pump and a micronizer? And yes, I read the section on CSV's website labeled "Micronizer and Standard Tank".
or
Size of Pump?
Pumping from?
Drop Pipe Material
PVC____N____
Steel___N____
Poly____Y____
Pressure Tank?
or
Pump Protection
Water Used For?
Plus/Or
Heat Pump______gpm?
