Under Sink Shut-off Valves
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by marshallized, Oct 11, 2009.
  1. marshallized
    marshallized New Member
    Sep 9, 2009
    Crestwood, IL
    Hi,
    When choosing a shut-off valve I see the outlet connection comes in either an 3/8" or 1/2" connection. How do I choose which one to get?. Is their any reason to choose one over the other?
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    depends on the faucet inlet size
  4. Terry
    Aug 17, 2004
    We mostly use 3/8" compression stops on the outlet side.
    My supplier doesn't stock 1/2" IP stops and a few 1/2 compression stops.
    [​IMG]
  5. jimbo
    jimbo Plumber
    The sizes available include 3/8 and 1/2 flare, 3/8, 7/16, and 1/2 compression, and 7/16 + 1/2 slip joint=1/2 ips thread. Valves and supply lines are available in all of those. BUT....the trade has widely settled on 3/8 compression as the size of choice. Since the actual flex supply tubes are pretty much all the same ID, there is no practical reason to use a larger size fitting if you are starting all new.
    Because of this de-facto standardization, there is the widest availability of valves, lines, accessories, adapters,etc. in 3/8 compression. Any other size, choices are limited and harder to find.
  6. marshallized
    Sep 9, 2009
    Crestwood, IL
    Thanks for the replies,
    Sometimes it seem like when doing a simple project their are to many options available to accomplish the same thing.
Similar Threads: Under Sink
Plumbing Forum, Professional & DIY Advice Under sink plumbing Jan 28, 2017
Plumbing Forum, Professional & DIY Advice Overflow tube under sink that seems to no longer exist Jan 17, 2017
Plumbing Forum, Professional & DIY Advice How to seal bathroom under sink hole &a kitchen marble counter top edges? Nov 18, 2016
Plumbing Forum, Professional & DIY Advice Musty smell under bathroom sink Oct 15, 2016
Plumbing Forum, Professional & DIY Advice Fixing Pipes in Basement Under Kitchen Sink Oct 13, 2016
