Ugh. Tapping into sanitary T below basement slab.
puckhead
Richland, WA
Need to run 2" shower drain to this 3" stack. Wasn't expecting a long sweep sanitary T to be just below the slab. Cutting out the T isn't much of an option since there's fittings immediately to the left and right so no open run for a union.
Maybe a saddle of some sort? Cutting/jacking out more of the slab is not a good option.
Could sure use some helpful suggestions. Photo is rotated 90 deg - damn iPhone.
Much thanks.
Cacher_Chick
Test, Don't Guess!
A sanitary tee would not be permitted in that position; that is a TY fitting.
Your connection will need to be made further downstream in the horizontal run. The shower will also need a separate vent.
