Type of supply pipe to shower valve.
Discussion in 'Shower & Bathtub Forum & Blog' started by katman104, Aug 23, 2007.
  1. katman104
    katman104 New Member
    Aug 20, 2007
    Texas
    Hello,
    Is it ok to use CPVC 1/2 inch pipe to input of shower valve and then use copper to shower head and Tub spout?
    Thanks
    katman104:)
  2. Lancaster
    Lancaster New Member
    Nov 7, 2005
    Thats the way it is most often done around here.However,dont use plastic adapters to screw into the valve inlets,use the ones that are CPVC slip by brass IPS.And be sure to use a "drop ear" elbow at the shower arm so that it can be secured with fasteners.
    Copper is rarely used for water lines around here because the water is agressive,however for the shower riser and tub spout elbow copper is preferred for its extra rigidity.
  4. katman104
    Aug 20, 2007
    Texas
    Lancaster,
    Thanks for the information.
    Katman104
  5. katman104
    Aug 20, 2007
    Texas
    Lancaster,
    Is there a web site that explains what depth to mount shower valves behind the enclosures for proper fit when you put the enclosure in place. I have tried to get Moen to contact me by phone and email but, they have not done so.
    Or is this different for every install depending on the enclosure itself? Sure would appreciate any help on this from anyone since the bathroom remodel is to this point. Thanks in advance
    Katman104
  6. Lancaster
    Nov 7, 2005
  7. jadnashua
    The valves typically come with a plaster guard - a cover to keep things clean and help align the valve prior to installation of the finished wall coverings. Typically, there will be min/max lines on that cover for the depth. The guide also is the template of how big, where, and the shape of the hole that is needed in the wall. This is also usually discussed in the installation manual, which you can often find on their website. this varies and is specific for each company and each valve, so no generalizations are valid for an actual specific installation.
  8. katman104
    Aug 20, 2007
    Texas
    jadnashua,
    The AquaGlass one piece tub and shower unit is 326032A-R unit and the faucet is a Moen 82496BN.
    It has a plaster guard that has "thin wall" and a place that says "Thick wall" on it. I am not sure of the distance between the stud wall and the finished side of the enclosure so I do not know what depth to mount the valve between the studs
    Thank's for any help you can provide.
    katman104
  9. jadnashua
    You may need to study the shower enclosure drawings. As long as the valve sticks out and the enclosure sits between the thin and thick wall lines, the trim should fit.
Similar Threads: Type supply
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Just installed acrylic Delta Tub and 3 piece surround (attach to studs type) Dec 11, 2016
Shower & Bathtub Forum & Blog Leaking valve in shower - Have you seen this type of valve before? Nov 8, 2014
Shower & Bathtub Forum & Blog What type of repair options available for tub coat peeling? May 22, 2014
