type M copper for residential water supply
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rblick, Feb 3, 2007.
  1. rblick
    rblick New Member
    Apr 17, 2006
    I just ran new plumbing for my bathroom using tye M copper 3/4 and 1/2.
    A plumber just told we type M is not code for my area and I should have used type L. He also said not to freak out because type M is ok.
    After research I see that M is code for NY but not in my town. Also pressure rating is 700psi for 200 degrees as copared to 1000psi for type L.
    Does it really matter for a residential system operating at 80psi?
  2. Terry
    Aug 17, 2004
    It's not the pressure, it may be more to do with the corrosiveness of the local water.
    Though I've found that fittings will spring leaks too.
  4. rblick
    rblick New Member
    Apr 17, 2006
    that was my next question lookstome like the standard fittings are of the same thickness of type M. Are there different thicknesses on fittings?
  5. hj
    fittings
    No. And if the water is going to attack type "M", it will do it with "L" also, it will just take a little longer to start leaking.
Similar Threads: type copper
Plumbing Forum, Professional & DIY Advice Type of closet flange for 3" copper drain? Feb 18, 2014
Plumbing Forum, Professional & DIY Advice What is the difference between type L and type M copper pipe Aug 9, 2009
Plumbing Forum, Professional & DIY Advice copper types Oct 27, 2007
Plumbing Forum, Professional & DIY Advice Mixing copper types Sep 29, 2007
Plumbing Forum, Professional & DIY Advice Type M copper in basement Jul 7, 2006
