kacheln
- Messages
- 19
- Reaction score
- 0
- Points
- 1
Guys, would like some advice on this please.
I set my drain up for an alcove tub and everything has lined up pretty well, other than the drain shoe not being level. And I think this is due to the fact that the sanitary tee is not completely square (is that correct? is there a a built in angle to the sanitee to accomodate the 1/4" per foot drop?).
So I test fit my tub and it is not completely square to the tub drain ( I though the tub drain might have an angle to it, but doeasn't appear to) , I would say it is out of level by about 1/16" from one side to the other (front to back).
Sooo.....is this good enough? Should I maybe double up on gaskets and go with it?
I also could tear it all out, install my tub and then try to build everything through my access panel I cut to install the overflow.
What are your thoughts?
Thanks,
Scott
Thanks,
Scott
