Trimming Copper Pipe, Replacing Shut Off Valve
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by DC Newbie, May 27, 2013.
  1. DC Newbie
    DC Newbie New Member
    21
    DC
    I'm in the process of replacing a bathroom vanity, and in order to get it flush against the wall I need to trim back one of the water supply pipes which sticks out too far (pic attached). Plan to replace the shut off valve in the process. As my handle indicates, I'm a newbie at this stuff, but it seems like this is a relatively easy fix. Can I just trim the pipe by a half inch or so using a pipe cutter of some sort? And do I need to do anything to the pipe in order to seat the new valve properly (remove burrs, clean threads)? If soldering is the way to go, then I'll need to bring a plumber in.
    thanks for your assistance.
  2. speede541
    speede541 Member
    124
    San Francisco Bay area
    Something that works great for me is a oscillating tool fitted with a Dremel 482 blade. My particular tool is a cheapie pneumatic Harbor Freight unit, but there are a bunch of electric models available from reputable brands.
    This is a great setup for getting at even 2" copper installed in tight confines where a compression-type pipe cutter simply won't fit, and it doesn't rip the edges to shreds like a recip saw.
  3. hj
    26,539
    YOu can use anything you want to cut off the tubing, a cutter, small hacksaw, big hacksaw, SawZall, etc. But I would stay away from a reciprocating tool, because they might be difficult to hole in place without damaging the copper before it is cut off.
  4. DC Newbie
    21
    DC
    Thanks for the suggestion on the cutting tool. I should clarify that the vanity is not set yet, so I can pull it away from the pipes in the picture, leaving me with space to operate.
    Edited to add: do I even need to take the old compression valve off, or could I just cut the pipe behind it?
  5. Terry
    14,951
    We would use a sleeve puller first to remove the back nut it there was too little space and then a tubing cutter.
    A bit of Emory cloth to smooth the copper before sliding the new compression stops on and then snugging them on with an expandable spanner.
    Sometimes a hacksaw blade, but nothing with power.
  6. DC Newbie
    21
    DC
    thanks Terry. Was in line at Home Depot with a tube cutter in my hand when I read this so glad to hear I'm on the right track. Wish me luck!
  7. DC Newbie
    21
    DC
    So thanks to everyone's help and encouragement, I managed to swap out the old compression valve, cut the pipe, and install the new valve without too much difficulty. It got a little off kilter in the tightening process, but so far no drips.
    Now to see if this valve fits with the faucet supply lines...just kidding, already checked. I'm learning to think a few steps down the line as part of this renovation project IMAG0408_BURST002_1.jpg .
Similar Threads: Trimming Copper
Plumbing Forum, Professional & DIY Advice, Tips & Planning Ahead to Service Your Copper Pipes Jul 25, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Flushing Copper Pipe Jul 22, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Slip-on spout adapter's set screw DESTROYED my copper pipe - how to replace the pipe or alternative? Jul 9, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Copper Pipe Sizing and Fixture Calculations Jun 27, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Bending 1/4" copper tubing Jun 6, 2014
