Trim Closet Bend?
f_java@hotmail.com
New Jersey
Hello Guys,
Is it OK to trim down the closet bend? Mine is about 2" above the sub-floor.
Thanks for any info,
Tom
I can't tell from the photo what you will be using with that.
Are you using an inside flange or outside flange?
And is the pipe straight there, or is it bending, which can be an issue setting a flange on there.
I sometimes will use a spacer under the closet flange to make it closer to finished floor height.
f_java@hotmail.com
New Jersey
the clo
I attached the 4x3 closet bend to the pipe in the pic.
