Toto Neorest 500 MS950CG
Tonyleeming
Hi, just purchased the above but I don't have the mounting template for it. Got everything else!
Can anyone provide me with one or a link so I can print it off?
Thanks
Tony
WJcandee
Wise One
New York, NY
I have a PDF of the template, but I don't have a means to post a PDF to this site. I will try to send it to your Terry Love inbox on the upper right of this screen. PM me if you want it sent somewhere else.
Tonyleeming
y
Thanks, I downloaded it OK but I am not sure how to print it so it is the right size....it just wants to print it out on one sheet.
Tony
WJcandee
Wise One
New York, NY
y
Tony
I would use the known parts against the sheet and vary the magnification of the printing until they seemed to fit...
Is the template that important anyway? Can't you place the toilet on the flange and mark where to drill using the actual holes? I can see that a template could be useful to see if the unit is going to fit, but you already bought it.
Koa
Honolulu, Hawaii
You can buy ($19.00 + $10.00 shipping!) the whole packet which includes the template from Toto (888 295-8134 ex4) in case you get desperate.
Tonyleeming
Thanks for the replies. I was a bit concerned about the location of the front mounting block. I have to remove the toilet from its existing location, so I guess I can make a template using the hole pattern that was drilled to mount it in the first place.
