Toilet flow problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by retzman22, Jul 28, 2011.
  1. retzman22
    retzman22 New Member
    Jul 28, 2011
    Apex, NC
    First time homebuyer and just moved into this house. It has a well and septic. 1 toilet seems to flush and work fine. However the other toilet has issues. The tank seems to always be full of water but the bowl is pretty much empty. If you flush the toilet it fills with water rapidly but slowly drains out similar to a bath tub. Is the toilet clogged?
    I havent tried much due to being very new to the repairing toilet scene.
    Thank you very much,
    Ryan
  2. Terry
    Aug 17, 2004
    First make sure that the tube from the fill valve is pointed into the overflow tube.
    This is what refills the bowl.
  4. jadnashua
    Another thing that can slowly drain a bowl is something like dental floss caught. It acts like a wick. The toilet could be defective, but the most common thing is as Terry mentioned, the refill tube not being positioned properly.
  5. oranges13
    oranges13 New Member
    Jul 27, 2011
    Michigan
    You stated it filled rapidly, but that it drained slowly.
    Does it swirl and flush normally and then cease to refill properly?
    In my experience, a clogged or slow moving toilet will fill, fail to flush well and then slowly empty - usually ending with lower than expected water level in the bowl.
    Check what everyone else has suggested but I'd attempt a good plunge or two as well.
Similar Threads: Toilet flow
Plumbing Forum, Professional & DIY Advice Strange contraption: Toilet flapper built into middle of overflow tube Jun 11, 2014
Plumbing Forum, Professional & DIY Advice Need recommendation for Low Flow toilet, showerhead, and aerator for apartments May 15, 2014
Plumbing Forum, Professional & DIY Advice just broke my toilet trying to fix it :( overflowing => breaking the water fill valve Mar 13, 2014
Plumbing Forum, Professional & DIY Advice Toilet Back Flow Preventer May 9, 2013
Plumbing Forum, Professional & DIY Advice Second toilet line hits main one in opposite direction of flow to the ejector pumop? Mar 5, 2013
