Telling an inspector he is wrong
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lahabra, Feb 9, 2008.
  1. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    I think my inspector is wrong. How can I make him see his error without affecting his ego.
    A roofer friend of mine has warned me that if I offend or challenge him, he could become a stickler for the remainder of the project.
  2. TMB9862
    TMB9862 New Member
    Nov 12, 2006
    Ask him how he wants it done, then explain why you did it the way you did. Don't try to shoot him down too hard or he'll probably get pissy. If worse comes to worse call the building department and request a different inspector.
  4. jimbo
    jimbo Plumber
    Not saying inspectors never make mistakes....but exactly what did he rule on that you think is incorrect? They live and breathe the code books and local rules, so it would take some doing on your part to convince him he is wrong. How hard will it be to do it HIS way???
  5. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    This is related to a previous thread, the inspector said "The toilet vent needs to be upstream toilet".
    It would take a day to do it his way, and then it might be wrong.
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    dealing with inspectors
    the best thing you can do is ask the building
    department to send another inspector out to
    "verify and comfirm " the originals decision to flunk your work...
    becasue you have gotten others opinions that
    this work is ok.....
    if you live in some po-dunkey area where this inspector
    also delivers the mail, and is the justice of the peace,
    you might have troubles....
    keep things diplomatic, because you are dealing with
    Barney Fife...... in the form of a plumbing inspector...
    I have seen a few of them in the past,
    they dont even make 24k a year in Indiana, but the badge and authority goes to their heads...
    or maybe they get good health insurance, I dont know...,
  7. Mikebarone
    Mikebarone DIY Senior Member
    Feb 19, 2006
    Phoenix, AZ
    Just a thought...
    I ran into that exact situation when I was doing a bathroom remodel. My inspector, (that was an electrician prior to becoming a city inspector) was very cool. When it came time to inspect my toilet, shower, and sink drain and vent lines, he was almost sure that what I had put together wasn’t correct. (I, being human in nature, thought what I had installed was correct). My inspector called in another city inspector, (that use to be a plumber) for a second opinion, and sure enough, I guess what I had was wrong, and I redid what I had. My point is, (because we are all human in nature), make sure you are correct in what you have installed. If you have a friend, of a friend that is a plumber, see if you could have him come over and check out what you’ve installed. Maybe post a photo of what you’ve install, and let the experts and this forum that a look at it.
    I’ve also had an issue with some electrical work that I’ve done, where I did call down town, for clarification, and I did get another inspector out, and it did pass.
    Wish you the best of luck with this one!
    Mike
  8. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Why don't you just ask the guy what he wants? If you tell us what state you live in would help. I'm sure some of the plumbers on here will know the code your on. They will be more than happy to tell you what you did wrong. I'm sure your drain lines would fail in my state. Wet venting a basement bath is a no no. Like others have said you vent will get clogged the way you have it and once your floor is covered it is done.
  9. Terry
    Aug 17, 2004
    He posted a picture of his toilet that he had plumbed.
    The wet vent was run at a 45 degree angle, which is considered vertical for code purposes, and run with a wye fitting, (Combo)
    If wet venting the lav over the tub was okay there, then it should have passed.
    Normally what I would have done in your spot, would have been to make him do a drawing of what he expected it to look like.
    Pipe and fittings are not that much anyway.
    In a rare case, I've asked for a different inspector, that was in Tacoma, and they do things a little different there on their commercial projects.
    I had discussed with the first inspector what I was going to do, then when the work had been completed, they sent an inspector out wear gold chains and his shirt open, with some talk of not letting his "boys" lose work to out of town plumbers.
    I called back the first inspector and got it back on track again.
    I still don't know if he was looking for a bribe or not.
    My father used to go down to Pierce County and try cases that involved Pierce County judges when they needed outside, non influenced judges.
    I had one case in Seattle, where an inspector turned down a 2" vent for a sink. He said it should be 1.5"
    Dooh!
    A call to the head inspector straightened that out. He was like,
    "Are you kidding me? You can always go bigger!"
    I told him, "Hey, it was your inspector out here that didn't like it."
    I mean, who even buys 1.5" no-hub cast iron?
  10. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    That animal doesn't even exist in hawaii.
Similar Threads: Telling inspector
Plumbing Forum, Professional & DIY Advice Before I get slammed by the inspector... May 26, 2015
Plumbing Forum, Professional & DIY Advice Inspector wants an RPZ for residential home Feb 20, 2012
Plumbing Forum, Professional & DIY Advice Replacing a leaking Instant Hot tank, Property Inspector LLC, Woodinville Jan 28, 2011
Plumbing Forum, Professional & DIY Advice Coming to a Plumbing Inspector near you Dec 7, 2009
Plumbing Forum, Professional & DIY Advice Inspectors suck !! Dec 8, 2008
