T&P valve on Tankless Heater
Discussion in 'Tankless Water Heater Forum' started by mae-ling, Mar 30, 2012.
  1. mae-ling
    mae-ling New Member
    Dec 8, 2011
    Vancouver, BC
    I have a Tankless heater, ever since I bought the house 1.5 years ago the T&P valve has been discharging slightly when you turn off a hot water tap. I was told this is normal. Is it?
    Now the T&P valve is leaking constant when you use hot water. The water temperature is not overly hot coming out of the relief vlave, I can hold my hand in a pail of it for a minute or so. Wanted to take a temperature on it but do not have a thermometer.
    The tank was at 50C and I turned it down to 40C and it leaks a lot less water but still does leak a little.
    We also had a power outage if that makes any difference, although we were on holidays, however 4 showers were taken and 3 loads of laundry done before it started to leak after we got back.
    Figuring I'll probably just change the T&P relief valve and see if that does it.
    Any other thoughts or ideas?
  2. Terry
    Aug 17, 2004
    I would change the T&P
    Sometimes they get something inside that prevents sealing.
    [​IMG]
  4. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    do you know the temp & press setting of the valve? is there any check valves in the system? it seems like it's narrowed down to a pressure issue. not overheating.
  5. mae-ling
    mae-ling New Member
    Dec 8, 2011
    Vancouver, BC
    Old pressure relief was 201f and 150psi(?) just going from memory, replaced it with the same and seems to be fine now.
    Thanks
Similar Threads: valve Tankless
Tankless Water Heater Forum Rinnai tankless popoff valve problem Oct 22, 2013
Tankless Water Heater Forum Do Tankless Heaters require pans and pop off valves? Jun 10, 2013
Tankless Water Heater Forum Tankless water heater pressure relief valve location Oct 14, 2012
Tankless Water Heater Forum shower valves and tankless Mar 25, 2012
Tankless Water Heater Forum Good/Best tankless heater valve kit Jul 12, 2010
