Stuck Moen shower stem valve
Discussion in 'Shower & Bathtub Forum & Blog' started by stuckshowerguy, Jun 25, 2013.
  1. stuckshowerguy
    stuckshowerguy New Member
    Jun 25, 2013
    Alaska
    Hi folks, looking for some advice on how to get a shower valve unstuck. A roommate broke the handle off a couple years ago, and i just put a new one on....and realized why the last one broke, the valve seems stuck. Won't push, pull, turn, nothing, nada. The wall plate says its a Stanodyne, picture is attached. From what I am seeing I have a feeling that if I call a plumber Im going to end up with a bigger hole in my wall and a bigger hole in my wallet, too. Any obvious tricks/tips/solutions to getting this valve to work?
    Thanks in advance!
  2. Terry
    Aug 17, 2004
    Moen 1225B cartridge will fix that.
    [​IMG]
  4. hj
    Moen
    quote; Moen 1225B cartridge will fix that. It WILL, after he gets the old one out, which is the problem he is asking about. The answer may be that YOU will not get it out, but a skilled plumber with the right tools, (and I have about 5 different ones to remove it depending on the situation and how it degrades as each tool is applied to the core), should be able to do it in a matter of minutes.
Similar Threads: Stuck Moen
Shower & Bathtub Forum & Blog Stripped or Stuck Moen Allen Screw Oct 30, 2016
Shower & Bathtub Forum & Blog Stuck set screw in Moen shower faucet Oct 14, 2010
Shower & Bathtub Forum & Blog Removing stuck handle from Moentrol Shower Body Jan 23, 2010
Shower & Bathtub Forum & Blog Moen cartridge was stuck, replacement leaks Nov 15, 2009
Shower & Bathtub Forum & Blog Moen cartridge stuck May 9, 2009
