Sprinkler Manifold
Discussion in 'Irrigation / Sprinkler Forum' started by TKinney, Jul 14, 2005.
  1. TKinney
    TKinney New Member
    Jul 14, 2005
    I have just "completed" constructing and gluing together my supply side sprinkler manifold. It is leaking at two of the joints. Is there anything I can do aside from rebuilding it from scratch to stop the leaking?
  2. Terry
    Aug 17, 2004
    From a plumbing standpoint, no.
    The joint must seal from the inside of the joint.
    Patching the outside is a waste of time.
    If you're using PVC fittings with purple primer and pvc glue, then you won't be out much time or money.
    As plumbers, we have all run into that sometime in our career.
    For threaded connections, some use Teflon tape, (carefull with this or the strands of it can float through your valves.)
    or you can use a Teflon based paste sealant marked for for use on plastics.
    I rarely ever use tape.
Similar Threads: Sprinkler Manifold
Irrigation / Sprinkler Forum Wiring Solenoid Valves for Sprinkler Manifold Dec 14, 2007
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Sunday at 3:14 PM
Irrigation / Sprinkler Forum Flow required to properly blow out sprinkler system Oct 22, 2016
Irrigation / Sprinkler Forum Sprinkler head problem Sep 18, 2016
Irrigation / Sprinkler Forum Inground sprinkler system SPLITTER? Sep 8, 2016
