Upper
DIY Senior Member
Hellow all,Great Site! I am going to install 2 solar pumps in different wells. One will be set at 80 feet,the other at 160 feet.TDH of 80 and 360 respectively.I would like to use polypipe in both.I am thinking the 160 footer with a TDH of 360 will need 200psi poly.I read on here of the uselessness of a pull rope.My question is,does the pullrope attach to the pump or the male adaptor that is coupled to the polypipe.Does the poly pipe ever come apart from the male adaptor?If so, then a rope would have some use.Also 360 foot of head equates to 160 psi at the bottom of the well.Hose clamp fittings or compression fittings? Anyway thanks for the site and any answers you might have...Upper
