John in herndon
Hello all,
I have a townhouse with 4 toilets on 3 levels. 3 of the 4 toilets flush just fine. One in a first floor powderroom has problems. It takes 3 or 4 flushes to remove solid waste. The water volume seems sufficient but the waste simply spins around i the neck of the toilet and refuses to exit. The toilet makes a rather loud "choking sound" as the water exits.
These are original toilets and have no discernible brand names on the bowl so I assume they are spec builders cheepos.
The waste line is 3" PVC which takes a 90° turn out of the flange, picks up the basin waste line and continues about 20 inches where it goes into the 3" PVC stack from the second floor bathroom above.
Does anyone have any ideas here? I will probably pull the bowl and look at the flange in the event there is an obstruction there.
Thanks for any replies.
John
John
