Noizboy
I'm remodeling my bathroom. I put in a new wider tub which moves the shower valve over about and inch.
Problem is it puts the valve closer to the cold pipe and farther away from the hot. There is also a T in the pipe to feed the sink in the master bath that backs up to this one. Normally I could lean the pipe to make up the distance, but because of the T in the pipe I only have less than a foot to play with. Do the two pipes on the side of the valve need to be the same length? If so how to make up the distance? Bend the pipes slightly?
Thanks in advance,
Brian
Thanks in advance,
Brian
