Shower Spout
heliosj
Florida
The water diverter on my shower spout broke off last night leaving me unable to turn on the shower. So I did a little search on the Internet and I've discovered there are two main spouts -- a slip off secured by a screw and a twist on secured with a thread. My shower spout does indeed have a hole at the very back of the bottom of the spout, leading me to believe it's a slip off with a screw. However, when I stick my finger up there, I just feel a rounded pipe, no screw or divot to undo. Does this mean my spout is a screw off? I tried with all my might and then with a wrench to turn it under clockwise, but it wasn't budging and I don't want to make matters worse.
Is there a 3rd type of spout that I haven't come across yet? What am I missing?
Thanks in advance!
PS - I'm 95% sure it's a Price Pfister spout.
PPS - This would be a lot easier if I could just replace the water diverter, but I can't seem to find one.
By their location, it is tough to feel or view the setscrew (assuming there's one there!). If there's a slot/hole/whatever there, there's probably a setscrew. It could be recessed quite a bit and you'll likely need an allen wrench the proper size to loosen it.
heliosj
Florida
I have an allen wrench of many various sizes, I tried to stick them all up there, but none of them fit into any hole.. I guess I'll try again in the morning. I haven't taken a bath since I was a kid, but I guess that's what I'll do for now. I just spent a fortune on plumbing recently, I'm bound and determined to do this myself.. :)
heliosj
Florida
Update..
I just crawled underneath the spout and shined a flash light up there, there's no place to stick an allen wrench or screw driver up there. I'm either a weakling or that thing is wedged on there.. or I'm missing something.
If it isn't a slip-on spout, then I've stuck the handle of a screwdriver (not the working end, the handle) into the spout and used that as a lever to unscrew it. Using the shaft end might just split the spout...the handle spreads it out a little more. If it is caulked to the wall, it can be a lot harder to unscrew...you usually need to cut through that first. Make sure you are turning it in the proper direction!
NBachers
San Francisco
Screw-on (threaded) types sometimes have cutaways
I always thought it was to provide drainage, but maybe it's because they can do a production run with the cutaway, and then adapt to either threaded or set-screw type. It sounds like you've got the threaded type that screws on.
As you're trying to twist it off, figure that counter-clockwise is the way to unscrew it. If it won't break free, then try turning it a bit clockwise, then counter-clockwise. You're trying to rock it into giving up it's tightness- kind of like rocking a car out of the snow. Tension in both directions can help break it free.
