Shower Head in Corner
Discussion in 'Shower & Bathtub Forum & Blog' started by DoofusOfTheDay, Dec 2, 2005.
  1. DoofusOfTheDay
    DoofusOfTheDay Member
    Feb 25, 2005
    Computer Geek with Big Blue
    Atlanta GA metro area
    Is it okay, or advisable to put shower head coming out of corner of neoangle shower I am building? I want to leave the valve and control on the wall where it is, to the left as you enter shower. Then route the pipe so the shower head comes out of the corner of shower. It would be the far corner you see as you enter shower. I didn't know if this would present problems with roominess, banging elbows on walls, or if technically okay. Thanks.
  2. Terry
    Aug 17, 2004
    When I plumb for a 38" neo-angle shower pan,
    I put the valve and the shower head at 14-1/2 from the rough corner.
    This will be where you stand in the neo-angle.
    Because of the angle, you don't really stand in the center.
    If you were to stand in the center, and were to bend over to pick up a bar of soap, your behind would knock the door open.
    And you had to ask.
  4. DoofusOfTheDay
    Feb 25, 2005
    hmmm...let me cite the dimensions(roughly) it will be. Still moving stuff around a little, but this should be pretty close. Doorless shower with 26" rough opening, that has 45 degree angle to adjoining walls. If you going left, 21" wall, 54" wall, 40" wall, 36" wall back to the other side of the opening. So my thought was, for less splashage, since doorless and even though we will be waterproofing floor, back corner, but again seems like that might be close quarters since in a corner. Maybe I should put it on 54 inch wall down towards the corner. Right now it's in the middle of 54" inch wall. I dunno just looking for thoughts on this. Thanks.
  5. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
    always keep your back to the wall when bending over in a shower! :eek:
    doof, maybe a nice heavy glass shower door with the geneva hinges. nice look in any bathroom. dealers sell certain sizes cheaper than custom. you could frame accordingly.
  6. DoofusOfTheDay
    Feb 25, 2005
    I think I am leaning towards putting the shower head on the far wall, and the valve inside to the left as you enter shower. That way you can turn on the water to warm up without getting wet. Also, the shower head on far wall will not throw too much water out the doorway, and I should have adequate elbow room. What is best way to route pipes? Do I route them through the studs around the perimiter of the shower to reach the shower head, or go down the wall and underneath the pan and up? I have full access as I ripped out the floor with the old pan due to water damage. I didn't know I could post pictures here. I will.
Similar Threads: Shower Head
Shower & Bathtub Forum & Blog Delta rain can shower head install Yesterday at 7:12 AM
Shower & Bathtub Forum & Blog Repl shower head using fpt coupling--Plan C:can't catch a break Jan 31, 2017
Shower & Bathtub Forum & Blog help finding shower head diverter Jan 28, 2017
Shower & Bathtub Forum & Blog Trying to replace shower head without pipe! Dec 12, 2016
Shower & Bathtub Forum & Blog Leaky shower head Oct 2, 2016
