Should Drake Tank Rock?
Discussion in 'Toilet Forum discussions' started by MissouriBen, Sep 7, 2007.
  1. MissouriBen
    MissouriBen New Member
    Sep 7, 2007
    Just put in a Toto Drake. Everything works fine, but the tank is able to rock front and back quite a bit-- it doesn't feel solid.
    Does this mean that I should tighten the tank bolts more? How do I know how far I can go without cracking the tank? Again, no leaks or anything, but it feels weird for the tank to wobble when the flush handle is used.
    - Ben
  2. Terry
    Aug 17, 2004
  4. jadnashua
    The longer it sits under compression, the easier it is to tighten down. Just tighten it down maybe 1/2 turn alternating sides. You don't want it to be so tight you are actually putting tension on the porcelain but you can get it so that it just about touches the base. At that point, there will be almost no movement.
    [​IMG]
Similar Threads: Should Drake
Toilet Forum discussions Should water be coming out of Toto Drake Fill Valve? Apr 18, 2016
Toilet Forum discussions Toto Drake - should I have to hold the flush lever? Mar 11, 2014
Toilet Forum discussions Drake - should I just shim it ? Any Ideas ? Jul 18, 2009
Toilet Forum discussions TOTO Drake: Should the tank lid be level Feb 28, 2008
Toilet Forum discussions Should You Flush That Wipe? Dec 26, 2016
