greysun
I have a 3" sanitary tee. Unfortunately the top of the tee is too low. about 1.5 inches below the finished floor. If I insert a 3" flange into the inside of the tee it only goes in about 1/2 to 3/4 inch. I am afraid this is not enough. If I put a piece of 3" pvc inside the tee and then try and put a 3"-4" flange that goes on the outside of the 3" pvc the flange sticks up too high because the bottom of the flange meets the top of the tee.
I am kind of at a loss. This is a second floor bathroom so I am really hoping for a glued solution, or at the very least one of the repair flanges with the expandable gasket. The problem is I don't think they make a 3" flange with expandable gasket, probably because it would reduce the flow area down too much. The twist in replacement flanges make me very nervous. I am afraid that the first time I have to plunge water is going to blow by the gasket.
What I really need is a flange that has an outside diameter that is the same as 3" pvc so I can insert it directly into the tee, but is at least 1.5 inches longer than the standard flange.
Something else I was thinking about was buying one of the 3"-4" flanges that fits on the outside of the 3" pipe and cutting down the neck about an inch. but I think this would only leave about an inch of flange neck going over the PVC pipe.
Am I right to be afraid of the twist in replacement flanges?
Is there a 3" repair flange with the gasket that expands by tightening screws inside the flange? and if so would this cut down the flow too much?
If I cut down the neck of a 3"-4" flange about an inch would I still be safe?
Does anybody have any recommendations on the best way to handle this?
Thank you in advance for any help or advice you can give.
