Tacitus
Hi guys!
I'm in the middle of renovating my kitchen and part of the process will involve replacing the old electric range with a gas one (My Italian fiance will cook on nothing but gas). The wall where the range will butt up against has a gas line running right above it. The line used to run to a gas furnace, but the furnace was replaced with a heat pump sometime in the past before I bought the house and has been capped off.
My plan is to tap into the line running above the wall with a 90 fitting and run the line down the inside of the wall where it will hook to the new range. Before I pull a permit my questions are:
- When running the new pipe down the wall, are there any special hangers I need to attach the gas pipe to the stud, and what is the recommended spacing of the hangars/brackets?
- Is there any rules regarding proximity to electrical lines? If I drop the gas line down the inside of the wall, it will intersect an electrical line.
With all the help from my previous post on my bathroom renovation, I was able to pass the city inspection with flying colors, once again thanks for all the help!
