Sometimes I come across a job that has been hacked in with the wrong parts.
A Fernco coupling without the metal wrap is not allowed, and p-traps with unions are not allowed.
This shower drain was leaking, so it all had to come out.
You can see the water spoting on the p-trap.
I've never seen this before. The handyman put one end over the hub of the p-trap and the other end over the pipe. That would be very strange to try to run a snake through.
What is the white cauling up on the drain fitting? I'm not liking that either.
Please don't anybody use these parts again. Non of this is right.
Cut that entire mess out and start over. We installed a Sioux Chief JackRabbit shower drain.
And this p-trap is solvent weld. It glues up instead of using a union that can leak, and the Fernco has been replaced with a glue on coupling. Now it holds water.
