Rear discharge toilet seal options
Discussion in 'Toilet Forum discussions' started by doitright, Jan 24, 2008.
  1. doitright
    doitright Tile & Stone Specialist
    Oct 17, 2004
    Custom Ceramic Tile & Natural Stone Installation C
    Mundelein, IL
    Hi Guys :)
    We just removed a rear discharge toilet that's been leaking for enough years to rot the wood etc.
    I just purchased a Zurn gasket with sealant, but it's too small (to make a good connection at the wall flange).
    Anyone have any suggestions that will create a failsafe water tight connection. Unfortunately the this unit sits on the floor and will have to be tiled in.
    Thanks in advance.
  2. Terry
    Aug 17, 2004
    They do make wax seals that are for wall connections. It should state that on the box.
    When you say,
    "Tiled in"
    What do you mean?
    Normally, the wall or floor, or both are tiled, and the toilet bowl sets on the tile.
  4. doitright
    Oct 17, 2004
    Mundelein, IL
    Hi Terry :)
    I'm aware of how it's supposed to be installed. Unfortunately the floor has been previously installed over several layers of wood underlayment over two layers of tongue and groove slats. My client already installed vanities and partition walls over the existing floor and tile.
    We removed the mosaic and replace any bad wood, but by the time we put on our isolation membrane for the marble (Ditra), we are out of room to raise the toilet any higher. To further complicate things, this wall hung backs up to another wall hung in another unit, so the flange can't be raised.
    Bottom line we have to install the toilet on the Ditra, and marble up to the toilet. :eek:
  5. Terry
    Aug 17, 2004
    What kind of shape is the wal flange in?
    Kind of pins you in, but that's the situation I guess.
    The wall mount wax is made a bit different.
    I hope that works out okay for you.
  6. hj
    seal
    I would use a neoprene sponge rubber gasket.
    I forgot about those, they are bigger than the Zurn washers.
    That would be better than wax.
Similar Threads: Rear discharge
Toilet Forum discussions rear discharge toilet---does it need a special flange? Apr 16, 2015
Toilet Forum discussions Need to replace rear discharge floor mounted toilet Help! Mar 15, 2015
Toilet Forum discussions Toto for rear discharge installation Mar 10, 2015
Toilet Forum discussions Rear discharge toilet Dec 18, 2014
Toilet Forum discussions Wall hung toilet or floor standing rear discharge toilet? Oct 23, 2014
