Pressure tank distance from well pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by w4mjr, Feb 11, 2012.
  1. w4mjr
    w4mjr New Member
    Feb 11, 2012
    Middle Tennessee
    I have a question about the distance of putting my pressure tank from the well. My well is 65 feet deep. I would like to my pressure tank and pressure switch in the corner of my shop that is 160 feet away from the top of well casing which would make the total length 225 feet to the bottom of well. Would that work ok or do I need to place the tank at the top of well casing but then I would have to make a small well house for the pressure tank only and I didn't want to do that. I read where some people place the tank under the house crawlspace of there house which is kinda the same setup. My plans are 3/4 hp subm pump with 20 gal pressure tank. Water is used for outside only.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Put the tank where you want. In the case of a 600 foot deep well, the tank would be further away than that.
  4. ballvalve
    Dec 28, 2009
    northfork, california
    I have a tank 1000 feet from the well. Its the switch you want near the tank.
  5. w4mjr
    w4mjr New Member
    Feb 11, 2012
    Middle Tennessee
    Ok thanks. Just what I needed to know. I guess where I read on some of Lowes pumps the lift is 150 feet and I was taking it as the total pump distance. That must be something else.
Similar Threads: Pressure tank
Pumps and Tanks Well Forum & Blog. Water is life. Well pressure tank help. Today at 3:44 PM
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Feb 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Want to change well tank pressure Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wellpump and pressure tank mismatch? Jan 26, 2017
