Power Gravity (blue) Flapper in a Drake & Drake 2 (Gwyneth)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tyneskj, Aug 21, 2009.
  1. tyneskj
    tyneskj New Member
    Aug 21, 2009
    Okay, so I have tried swapping the red (g-max) flapper with the blue (power gravity) flapper in a Toto CST744S Drake and the water flush volume increased from 1.6 gallons to almost 2.6 gallons (almost 60%).
    1.Has anyone tried the same flapper swap in the Drake 2 (Gwyneth), with the 1.28g/flush?
    2.On the Drake 2, I've noticed a float on the g-max flapper chain for the Drake 2 anyone tried just taking that off?
    And before people start asking why... It's a customer request.
  2. tyneskj
    tyneskj New Member
    Aug 21, 2009
    This is perfectly good info., and a valid question, but thx. for the "manufacturer's" input. Glad to get that out of the way first!
    Anyone tried anything on the Drake 2 (Gwyneth)? Peanut9199 maybe are you around?
  4. Terry
    Aug 17, 2004
    I don't know anyone yet that has changed the flapper on them.
    It would be a simple change out though.
    The Blue flapper floats longer, so more water drops out of the tank, that's the only difference.
    [​IMG]
    Looking inside the CST454CEFG Drake II tank.
  5. tyneskj
    tyneskj New Member
    Aug 21, 2009
  6. jadnashua
    Most of this concern (at least with Toto brand) on 'not enough water' when flushing is unfounded. Toto has a very good track record...they generally don't put products out there that don't work. Leave well enough alone. On the rare occasion when for whatever reason it doesn't clear on the first shot, it certainly will the next. In the 5-years or so I've had my Totos, I think maybe once every 3-4 months it might need a second shot, and then it's because there are a bunch of small floaters...depends on what you eat.
    Since they use pretty much standard parts, you can modify it, if you decide you need to. You won't be getting the water savings. 99.9% of the time, it gets the job done with a single flush...don't beat a dead horse...this is not yesterday's poorly designed toilet!
  7. Terry
    Aug 17, 2004
    I have the Gwyenth installed.
    If you hold the handle down, that is like using a bigger flapper.
    You can hold the handle down till the tank is empty, I don't know how much more you can do than that.
    But that had already been mentioned.
    So the answer is no, the water will not jump out of the bowl and race around the bathroom chasing your kids.
    Though the kids would think that was fun.
Similar Threads: Power Gravity
Plumbing Forum, Professional & DIY Advice Running underground power & water lines Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Buderus GB142 - no power Oct 10, 2016
Plumbing Forum, Professional & DIY Advice Half power in my trailer Feb 21, 2016
Plumbing Forum, Professional & DIY Advice Thermar super power pack Feb 17, 2016
Plumbing Forum, Professional & DIY Advice The UK’s first food and poo-powered bus Jan 22, 2015
