possible to increase water pressure?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by skarb1188, Sep 6, 2008.
  1. skarb1188
    skarb1188 New Member
    Sep 6, 2008
    House water pressure OK, but looking to increase it if possible. Currently Pumptrol settings at 30/50, water tank pressure at 27. Goulds Jet pump 1/2 HP. Can this type of jet pump handle a setting of 40/60 & increased water tank pressure to 38? Will I get any increase in shower pressure?
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    It depends on which 1/2 HP shallow well jet pump you have.
    If you have the J5S it probably won't work reliably at 40/60.
    If you have the J5SH it will work at 40/60.
    http://www.goulds.com/pdf/7297.pdf
    If you look at the nozzle and venturi part numbers in the table at the link you will see what the difference is. If you have the J5S you can substitute the nozzle and venturi for the J5SH and get the J5SH performance. The rest of the parts are the same.
    http://www.goulds.com/pdf/7381.pdf
  4. skarb1188
    Sep 6, 2008
    The Model # on my Goulds is J05N , so I'm not sure which model (J5S, J5SH) it compares to, if at all.
  5. Bob NH
    Oct 20, 2005
    New Hampshire
    The pump is a J05; the N stands for "Not Tank Mounted".
    The pump is obsolete but you can still get the required nozzle and venturi.
    The parts list at the link says the high pressure nozzle is AN019 and the venturi is AD3528.
    http://64.233.169.104/search?q=cach...ETSU.pdf+j05n+goulds&hl=en&ct=clnk&cd=1&gl=us
    Those parts are the same as for the J5H in the current Goulds J+ Series. See parts list at the link.
    You could try increasing the pressure setting, or just jumper the switch and see how high it will go; but don't run it too long at that condition. You could have the high pressure parts in the pump.
    You will get lower flow with the higher pressure parts.
Similar Threads: possible increase
Pumps and Tanks Well Forum & Blog. Water is life. Possible to replace bladderless tank with bladder-type tank? Jul 24, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Possible Replacement of Pressure tank Needed Nov 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well head cover impossible to get off Nov 13, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Best pump for hard water also, please review our setup & suggest other possible improvements Oct 22, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Septic Tank-possible problem. Sep 13, 2013
