Plumbing Layout Review
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dsanchez, Oct 23, 2012.
  1. dsanchez
    dsanchez New Member
    Oct 23, 2012
    Ontario
    Hi There.
    New to the forum but would appreciate some review and feedback on some plumbing I plan on doing shortly. I'm adding 2nd floor WC and moving an existing WC.
    Just looking for some feedback regarding, if there are any issue with the set up, fittings used or code violations. Also any helpful 'gotchas' that you may know of that I should consider.
    Also had a couple questions:
    1. Started dry fitting some of the piping together and I'm concerned I won't get the proper slope (1/4" over 1') on the horizontal run in the 7.5 inch void. Any suggestions? Maybe I should be use floor flange with 3" inside fitting?
    2. I have an existing bulk head in the kitchen on 2 sides. I'm hoping to match up the new bulk head on the same level but again I'm worried about the 90 and long sweep 90 causing the bulk head to be lower than the existing ones and not being able to tie the bulkheads together nicely. Any thoughts?
    I've attached a side and over head view of drawings to illustrate the plumbing set up and fittings. The drawings aren't to scale and I'm not a drafter but hopefully these are good enough to get the idea.
    View attachment Plumbing Diagram.pdf
    FYI. I live in Ontario, Canada.
    Thanks in advance for you feedback.
  2. dsanchez
    dsanchez New Member
    Oct 23, 2012
    Ontario
    I guess because I'm new no one trusts the attachment??
    Here's a jpeg of the diagram. Any expert opinions would be appreciated.
    Thanks.
  4. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    Venting needs help.
    Need a 2" vent for the toilet.
    Also each toilet should be vented.
    On the lower toilet vent needs to be before the wye where the lines tie in together.
    The two vents can tie together 6" inches above the flood rim, but common practice is to tie together at 42" high.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I don't think he needs 2" in Canada, 1-1/2 is ok I think. He needs to check his code though. IPC would let both toilets go without a vent as long as there was one somewhere in the house.
  6. dsanchez
    dsanchez New Member
    Oct 23, 2012
    Ontario
    Thanks guys. Maybe i'll go with 2" just in case
  7. hj
    Flowing one toilet past the connection to a second one DOES need a vent, regardless of the required size, preferably at the point where the two meet, or else individual vents on each toilet line.
  8. Terry
    Aug 17, 2004
    I looked at a similar situation in Seattle last week. One vent, two toilets, with one coming in horizontally on a wye after the first. One bowl works fine, but the other toilet loses water when the other toilet is flushed. Like hj, I think that you will need to make sure that each bowl is vented. With the new toilets that flush quicker, how they are plumbed is changing. The design after the water leaves the bowl is becoming "more" important, not "less".
    With the Seattle home, older slow functioning bowls had been working. Changing to toilets with 3" flush valves changed that.
  9. dsanchez
    dsanchez New Member
    Oct 23, 2012
    Ontario
    Thanks all. So will one vent after the wye work or are you saying I need to vent both toilets separately regardless?
  10. Terry
    Aug 17, 2004
    I would future proof your home by venting each toilet "before" the wye.
    In my own home, when I remodel the baths in the upstairs, I will be changing how the plumbing is routed for the toilets. The old ways no longer work.
  11. hj
    Either vent AT the "Y" so neither toilet can encounter a "pressure problem" or vent each separately.
  12. dsanchez
    dsanchez New Member
    Oct 23, 2012
    Ontario
    Thanks for the advice, much appreciated.
    One more question.. so if I run another vent at the wye where the toilets meet then I'll need to run the vent horizontally (slight slope) back to the shared wall of the toilet. it would be about 3' before the vent would travel vertically.
    Any issues with this?
  13. Tom Sawyer
    Nov 29, 2010
    Maine
    Yep, You can't run a vent horizontal until it is 6" above the flood level rim of the highest fixtures served.
  14. hj
    Yes, because it is horizontal, but a "vent Y" between the closet bend and the toilet's "Y" would NOT be 3' from the wall.
  15. dsanchez
    dsanchez New Member
    Oct 23, 2012
    Ontario
    Ok. But even if was right after the bend it would still need to run about a 16 - 18" horizontally back to the wall is this ok? If not how do I vent the second toilet?
  16. hj
    Roll the "Y" above the centerline as high as possible. IT will not "conform" to code, but will work.
Similar Threads: Plumbing Layout
Plumbing Forum, Professional & DIY Advice 2nd Floor Plumbing Layout Jun 27, 2016
Plumbing Forum, Professional & DIY Advice Rough plumbing layout w/ backwater check valve. May 21, 2016
Plumbing Forum, Professional & DIY Advice Basement bath plumbing layout May 10, 2016
Plumbing Forum, Professional & DIY Advice Help With Plumbing Layout For Bath And Kitchen Renovation Apr 28, 2016
Plumbing Forum, Professional & DIY Advice Advice on my reno plumbing layout Mar 28, 2016
