Pegasus shower and tub control valve no hot water
Discussion in 'Shower & Bathtub Forum & Blog' started by gmpg19, Jan 2, 2008.
  1. gmpg19
    gmpg19 New Member
    Dec 30, 2007
    I recently turned on my secondary shower to find that the hot water side of the divertor no longer produced hot water. I removed the trim plate and could see nothing out of the ordinary. Any suggestions on a fix? the unit is basically new as it is only used when company is in town. I took the internal apart and found nothing ?? nothing appears to be stuck, the spool was moving freely, there was 2 ports I presume hot and cold. However I can only get cold out of the volumne control valves, the adjustment screw on the hot turns in and out but no water will come out until the cold adjustment volumne control is turned out. Even when I take out the stops on the spindle shaft and free spool the valve 360 degrees I still get no hot. It will shut off in 2 spots as I turn the spindle but no where on the rotation will it give me hot. The vanity beside the tub gets hot though???
    Thanks
    Unfortunately I have company for Christmas and no hot water -- please I need help.
    Thank you
  2. Terry
    Aug 17, 2004
    If the water is warm, but not hot, it may be that the temperature limit stop needs to be adjusted to allow the handle to move farther over to the left.
    I've noticed that they are set from the factory pretty low.
Similar Threads: Pegasus shower
Shower & Bathtub Forum & Blog Replacing cartridge for Pegasus Shower Sep 9, 2013
Shower & Bathtub Forum & Blog Mystery shower valve? Danze, Global Union, Pegasus Dec 13, 2012
Shower & Bathtub Forum & Blog how would you guys handle this? just had a Pegasus shower valve installed. Apr 17, 2009
Shower & Bathtub Forum & Blog Problem with lukewarm temp on Pegasus 1/4 turn 1 handle shower/tub Dec 3, 2008
Shower & Bathtub Forum & Blog Pegasus shower and tub hot cold valve problem - No hot water Dec 31, 2007
