Options to reattach or replace tub spout
sheruty
San Francisco
My tub spout came off and I cannot reattach it. It is a diverter spout, but the threads are at the back of the spout and there is only a very small section of pipe protruding from the wall. It is so small and worn that I cannot get the spout to screw back on. I've tried using teflon tape but it won't stay connected once I turn the water on. I cannot find this type of diverter in the stores. Are there replacements to this type, or are these obsolete? What are my options for reattaching, or do I need to hire a plumber to go behind the wall to fix? Photos are provided.
Jim Mills
nebraska
Looks like that tile was set over the old tile & covered most of the threads on that spout adapter. Not enough info to give detailed advice. Prolly need a plumber...
JGrant
North Carolina
I agree.
There is a pipe nipple back in the wall. You may need an "easy-out" to remove that.
Pick up a new tub spout, and a new nipple and install.
The spout you have is broken.[/QU
Can you look at my video and offer any suggestions? This is at my daughter's Condo built in the 1970s. I think she has the same spout in this thread. No set screw on the spout. There was a slight crack at the bottom so I carefully chiseled and removed the spout to reveal the plastic piece you see.
I suspect that I can take a channel lock and unscrew it but wanted someones opinion that knows what he is doing so I don't flood the house. I can't tell from the pics. Is the plastic threaded to a copper nipple. What size?
Link is below...........
Remove the adapter then either screw a new spout to that thread or use a coupling to extend the pipe depending on which type spout you get, but get a metal spout, not a plastic one or one with a plastic internal piece.
