swansok4
The outdoor spigot on the exterior of my wall had a small leak. It is a frost free sillcock style spigot. It mates flush up against the wall.
I tried to fix it by removing the spigot and changing the gasket. While removing the packing nut the nozzle itself moved and than disconnected entirely from the wall. Apparently the nozzle was never permanently attached to the pipe. It was just jammed on there. The attached picture 1 and 2 show the outside wall (the drip has stopped once all the extra water drained out) and the detached nozzle.
At this point I decided to try and go into the wall and just detach the sillcocks piping from the main pipe and replace the whole thing. Once I opened up the wall I discovered the connection between the sillcock pipe and the main pipe is hidden behind the corner of the wall and has bad access. The attached picture 3 and 4 show the interior access.
I can pound the nozzle back onto the pipe and reattach the whole system but that concerns me because there is no sort of screw or solder or adhesive attaching the nozzle to the pipe.
Would a plumbing adhesive (like loctite) placed around the nozzle before jamming it back on provide enough of a seal?
Should I open the wall up even more and remove the whole frost free sillcock and solder/screw on a new one?
Any other suggestions?
