New Home Plumbing/Water Softener
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Dbrule013, Nov 8, 2008.
  1. Dbrule013
    Dbrule013 New Member
    Nov 6, 2008
    I bought a new house in AZ a few months ago. I would like to have a water softener installed but am confused by the PEX plumbing in the house. Looking at another house in mid-construction the main line comes into the house wall and immediately is split into (2) cold supply lines. One line is smaller and goes across the garage ceiling toward the water heater. It then tees off and feeds both the water heater and the washing machine. The larger supply line also goes across the garage ceiling and then feeds the rest of the house. First, any idea why it splits right when the main enters the home? Also, for a water softener to be installed could the (2) supply lines be recombined in the garage, sent through the softener, and then split again?
    Thanks for any help!
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Possibly to avoid the expense or some mechanical limitation related to a single, still-larger line, or maybe to build in some redundancy in case either of those lines ever fail.
    If neither line supplies any fixture, faucet or spigot along the way, I cannot see why not.
  4. Dbrule013
    Nov 6, 2008
    Thanks for the reply. The only difference in my house to the house I looked at is that I have a 1/2 bathroom between the water main and garage. I would be surprised if the line isn't split before it hits the garage.
    Well, I have a plumber coming over next Friday to give me a quote on plumbing the softener in. I'm just trying to figure out the pain he might have to go through to get it in.
    Thanks, again.
  5. Jay Mpls
    Jay Mpls Master plumber
    Sep 29, 2008
    Master Plumber /Sewer rat
    Minneapolis
    The split is usually...
    1 softwater line.
    2 Hardwater for outside faucets.
  6. Gary Slusser
    Retired
    You don't mention anything about a drain pipe there so you don't have a standard softener loop but, yes, you can redo the two lines so you get softened water to both. Why it was done that way... it is what it is but usually they run lines the shortest distance, and now it doesn't matter anyway. The potential problem, although livable, is the 1/2 bath possibly not getting softened cold water; it will get soft hot water though.
  7. Dbrule013
    Nov 6, 2008
    I don't believe any of the drain lines use the garage walls. However, I am hoping the plumber will be able to tap into the 1/2 bath drain line. The sink is only about 2 feet away from the garage wall.
Similar Threads: Home Plumbing/Water
Plumbing Forum, Professional & DIY Advice Dumb question: will a lateral vent prevent a backup event inside the home? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Home run w/PEX how about a heat circulating pump? Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Brass cleanout plug in older home Jan 31, 2017
Plumbing Forum, Professional & DIY Advice No water in mobile home Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Radiant Heat If existing home directly on slab Nov 22, 2016
